by bagel » Mon Dec 17, 2018 2:13 am
bagel
It does work. I use RealFlow fluid simulations.
On your mesher make sure that VelocityX, VelocityY, and VelocityZ are selected. Then once your sim is all configured and mesher is tweaked appropriately, you can right click the mesher object (not the parent, that won't work!) and select bake to alembic and delete. Let it run through the sim and voila! Then in the Octane object tag, under the motion blur tab, you need to select Vertex Speed, tick the drop down, and drag the appropriate vertex map into each field. Motion blur works fine.
Presumably, whatever is generating your cloth mesh can be baked to alembic as well.
Also, you can bake volume mesher in R20 to alembic, but I haven't figured out how to export vertex speed as well.
I hope that helps a little. I know you're not using RealFlow per se, but it's good information. You have to be able to have a method to generate the vertex maps prior to exporting.
