Hi
I tried a search of the forum for this but came up dry so I'm wondering if there are any Octane users here who have also come from Arnold and who know how the two compare?
I've had Octane for a while but only just found the time to start playing with it and I must say I'm loving the speed but there are a couple things I feel I'm missing. To start with I'm wondering if there is a way to drive parameters with textures in the way you can with Arnold? For example, with Arnold I often drive the weight (or mix) with a texture which runs through a float_ramp node but with Octane I don't see any inputs to connect my textures into the mix parameter. Instead it seems like I basically load a texture in and then I have a mix slider to mix it with a colour but this just seems like it's cross-fading the opacity of the colour and the texture if that makes sense rather than being able to push the colour to 100% and use the texture's luma values to control how much of that colour comes through.
I did see that there is a node called Mix Material with which I can (in a round about way) achieve the same thing but there are some things that would be quicker if I could simply drive anything with either a texture or float or whatever.
While on that subject I do also miss having a ramp float node as I use that for almost everything, using the curve a great deal to control the values of mattes.
Then there's Arnolds Curvature node which is great for creating mattes on edges or corners etc (then multiplying it with textures to create scratches or peeling paint etc.
Finally I also wondered if there was something similar to the layer_color node (which may or may not be part of the 3rd party alShaders pack?). This is like the Octane Mix Material node on steroids and allows you to stake about 10 layers and each one of those can be driven by another texture or value and also each layer has a full selection of different blending modes.
I'm sure there's a ton more stuff I'll have to work out and judging by a lot of the work I've seen out there, I expect all of this has some form of solution but for now, these are some of the things I'm really missing so if anyone has any thoughts I'd love to hear back
EDIT: Sorry for the double post - the page timed out and I think me refreshing the page must have created two submissions. I have deleted the duplicate thread.
