Alembic Particle Geo and Octane.
Forums: Alembic Particle Geo and Octane.
Moderator: aoktar
Postby Rrock » Tue Nov 01, 2016 3:17 pm
Rrock Tue Nov 01, 2016 3:17 pm
So i got a grain simulation from Houdini in Alembic format.
Imported Alembic in C4D, selected "Points - As Particle Geometry" in Alembic Import Settings.
And then, when i selected Particle Geometry and applyed ObjectTag, there is no particle related tab inside object tag, so i cant render that particles.
Rrock
Re: Alembic Particle Geo and Octane.
Postby aoktar » Tue Nov 01, 2016 3:28 pm
aoktar Tue Nov 01, 2016 3:28 pm
It's not surprising. Because it just support the Oparticle(standard emitter), RFRK_PARTICLER, ID_TFD_FLUID_CONTAINER, OXPEmitter(Xparticle), OXPDomain. It's not a simple progress to add a support for a specific object type.
Postby pasto » Sun Nov 27, 2016 12:16 pm
pasto Sun Nov 27, 2016 12:16 pm
Hello,
I had the same problem, import particles from Houdini as points :
Octane on c4d doesn't recognize points directly (as it does in the houdini version though).
So I just made an Octane scatter object and pointed it on the alembic import.
You'll have to import the alembic in geometry mode (not TP mode).
It is quite nice though because you can add some variations with effectors if needed.
Cheers
pasto
Postby aoktar » Sun Nov 27, 2016 2:18 pm
aoktar Sun Nov 27, 2016 2:18 pm
pasto wrote:Hello,
Cheers
Brilliant! Do you use vertex distribution?
Postby pasto » Sun Nov 27, 2016 9:36 pm
pasto Sun Nov 27, 2016 9:36 pm
Thx Aoktar,
yes simple vertex distribution, the max number is bypassed I guess.
pasto
Postby Stylow » Fri Mar 30, 2018 11:06 am
Stylow Fri Mar 30, 2018 11:06 am
pasto wrote:Hello,
Cheers
You've just made my day!
Stylow
Postby mesut » Thu Apr 19, 2018 12:18 pm
mesut Thu Apr 19, 2018 12:18 pm
aoktar wrote:It's not surprising. Because it just support the Oparticle(standard emitter), RFRK_PARTICLER...
so, is this supposed to work, still?
using the RFRK_PARTICLER with a bin-particle sequence and adding an object tag to it, it actually offers "particle rendering" in the object tag.
but nothing is being rendered? is it to be used in a somewhat different way than it is used with e.g. xparticles?
how does this work?
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
mesut
Postby mesut » Fri Apr 20, 2018 12:50 pm
mesut Fri Apr 20, 2018 12:50 pm
no one any idea?
mesut
Postby jessestormer » Wed Nov 07, 2018 12:18 pm
jessestormer Wed Nov 07, 2018 12:18 pm
I am so happy to have found this post -- saving my life here. I have been trying to figure out how to import a simulation from Storm 0.2 for days.
Any idea on how to use the velocity information ?
If anyone has a thought on importing -- .ABC, .PRT or .BIN for use with Octane particles/scatter, would love pointed in the right direction!
jessestormer
Return to Maxon Cinema 4D
Who is online
Users browsing this forum: No registered users and 3 guests
Mon Mar 25, 2019 10:45 pm [ UTC ]
