Gamma Irregularity between viewers
Forums: Gamma Irregularity between viewers
Moderator: aoktar
Postby vrtx » Sun Apr 12, 2015 7:18 pm
vrtx Sun Apr 12, 2015 7:18 pm
I've been having a strange problem where all 3 viewers show a different perceived gamma/exposure value in cinema 4d. I'm NOT using the override kernal settings. The provided image will show what I'm talking about. I can get the lighting right in one view port, but it shows up completely over exposed in another.
Any help would be fantastic!
vrtx
Re: Gamma Irregularity between viewers
Postby aoktar » Sun Apr 12, 2015 9:08 pm
aoktar Sun Apr 12, 2015 9:08 pm
how could you got a succes to do this? Please read this notes:
Render Buffer
8 bit: Colors are converted 8 bit RGBA channels.
Float tonemapped: Colors are direct output of Octane Render and with tonemapping by camera imagers. Notify that colors will be clamped by max. 1.0. This works well with 16/32 bit images(tiff,exr,etc..)
Float linear: Colors are direct raw output of Octane Render without tonemapping. Gamma=1.0. This works well with 16/32 bit images(tiff,exr,etc..). Linear color space for saved image, this is recommended setting to avoid user confusions. In Live Viewer, to get same colors, you should set gamma=2.2 and linear camera response of camera imagers. Also this mode supports unclamped color outputs.
Postby vrtx » Mon Apr 13, 2015 1:19 am
vrtx Mon Apr 13, 2015 1:19 am
Wow thank you!
I'm using linear response in my camera settings, 16bit tiff, and "Float Buffer" under render buffer type. In octane settings "other" I have a 2.2 "Xbitmap Gamma". I'll try playing with these settings and see what I can get!
Thank you!
vrtx
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 7 guests
Sat Oct 19, 2019 5:00 am [ UTC ]
