Particles Sometimes missing from render
Forums: Particles Sometimes missing from render
Moderator: aoktar
Postby wetfusion » Wed Feb 01, 2023 8:34 am
wetfusion Wed Feb 01, 2023 8:34 am
missing particles on renders. im just using the native c4d emitter. below are the pics from 3 frames. frame 504, 505 and 506.
happens a few times already on other scenes. no problems on viewport.
c4d version : 2023.1.2
cuda driver version 12.0
OctaneRender Studio+ 2022.1 (12000020)
frame 504
frame 505
frame 506
intel 17 4770k (MSI MPOWER MAX)
32GB 1866ghz corsair dominator platinum
2x MSI 780 lightning
Plextor M5 256GB
wetfusion
Re: Particles Sometimes missing from render
Postby boxfx » Wed Feb 01, 2023 9:57 am
boxfx Wed Feb 01, 2023 9:57 am
Try baking the c4d particle system. I vaguely remember there can be problems because c4d's particles get recycled when the particle dies.
Otherwise you could try replicating what the particles are doing by using a cloner/matrix in mograph. Or maybe use a mograph cloner to clone onto the particles and just render the cloner geometry so octane never has to see the particle data.
boxfx
Postby wetfusion » Wed Feb 01, 2023 10:03 am
wetfusion Wed Feb 01, 2023 10:03 am
here is a simple test
frame 262
263
264
here is the test scene project https://we.tl/t-DYj0ccknlb
Plextor M5 256GB
wetfusion
boxfx wrote:Try baking the c4d particle system. I vaguely remember there can be problems because c4d's particles get recycled when the particle dies.
thanks bro. i will try it now :)
Plextor M5 256GB
wetfusion
Postby wetfusion » Wed Feb 01, 2023 10:59 am
wetfusion Wed Feb 01, 2023 10:59 am
i tried as @boxfx suggest.
baking the particle didnt solve the problem.
but putting the emitter as cloner object solve the problem. so its related to how octane reading the emitter particle data?
hope @aoktar can have a look at it and maybe fix it. :D
Plextor M5 256GB
wetfusion
Postby bepeg4d » Thu Feb 02, 2023 7:38 am
bepeg4d Thu Feb 02, 2023 7:38 am
Please always use the C4D Particles Emitter as source for a MoGraph Cloner in Render Instance mode.
In this way, also motion blur is supported:
ciao,
Beppe
Postby aoktar » Thu Feb 02, 2023 1:37 pm
aoktar Thu Feb 02, 2023 1:37 pm
bepeg4d wrote:Please always use the C4D Particles Emitter as source for a MoGraph Cloner in Render Instance mode.
ciao,
Beppe
Yes as Beppeg say you should use Cloner or particles tab from object tag. Otherwise no stable IDs to track the particles in motion engine.
Postby wetfusion » Fri Feb 03, 2023 12:28 pm
wetfusion Fri Feb 03, 2023 12:28 pm
thanks for the reply and advice. for the moment i will use mograph :)
Plextor M5 256GB
wetfusion
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 26 guests
Thu Apr 18, 2024 7:03 am [ UTC ]
