Octane Baking - UV Set
Forums: Octane Baking - UV Set
Moderator: aoktar
Postby Lipadoza » Thu Nov 24, 2022 2:10 pm
Lipadoza Thu Nov 24, 2022 2:10 pm
Greetings,
I am looking to bake the textures on a plant to a unwrapped UV map.
However the UV set tag on the camera does not seem to work, in fact having two UV's on a complex object crashes cinema all together.
Is it at all possible to bake one UV to another UV?
R23
2021.1.6 (R6)
Lipadoza
Re: Octane Baking - UV Set
Postby bepeg4d » Fri Nov 25, 2022 7:49 am
bepeg4d Fri Nov 25, 2022 7:49 am
In short, you cannot use different UV sets with c4doctane, you need to export to Standalone, and do the job there.
ciao,
Beppe
Postby Lipadoza » Fri Nov 25, 2022 3:27 pm
Lipadoza Fri Nov 25, 2022 3:27 pm
bepeg4d wrote:In short, you cannot use different UV sets with c4doctane, you need to export to Standalone, and do the job there.
ciao,
Beppe
Hey Beppe,
Thanks for the response.
Is it a limit from within Cinema or a feature not yet developed for the plugin?
As for the standalone workaround.
Would you be able to point me in the direction of a good tutorial to get started on that method?
Thanks in advance and have a wonderful weekend!
Kind regards,
Lipadoza
Lipadoza
Postby aoktar » Fri Nov 25, 2022 4:16 pm
aoktar Fri Nov 25, 2022 4:16 pm
Plugin limit. Also core has three set limit.
Postby bepeg4d » Sat Nov 26, 2022 8:09 am
bepeg4d Sat Nov 26, 2022 8:09 am
Hi Lipadoza,
you can prepare your Baking scene in c4doctane, and export it to Standalone via Render Settings/OctaneRender/Main/ORBX EXPORTER.
Then, in Standalone, just select the Camera node in Node Graph, and change the UV set in the Node Inspector:
And render the baked results from Standalone:
https://docs.otoy.com/StandaloneH_STA/S ... ight=batch
ciao,
Beppe
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 8 guests
Sat Dec 10, 2022 2:08 am [ UTC ]
