Hi, I've noticed that in the documentation there is no description about the fields Color Space and Force Tone Mapping: https://docs.otoy.com/cinema4d/OctaneRe ... tings.html
Hence, I have a couple of questions.
1. Before the tone mapping optiopn disappeared from render passes I used it to render the Z-Depth map wth correct values (like it was set up in the render preview with Z-Depth Max slider). Now, there is no tone mapping option in passes and disregarding the value I set with Z-Depth Max slider I always have a white rendered map. In After Effects I have to apply extreme exposure effect and adjust gamma to start using the depth map as expected. The Force Tone Mapping which migrated from passes to "main" settings tab doesn't make any different when we're talking about the Z-Depth. What's the proper way to render Z-Depth in such a way that I can send it to someone else who won't have to guess what level of exposure they must apply to the rendered map?
2. Can you, please, explain what's the logic behind the Force Tone Mapping and how we can use it to our advantage?
P.S. The link doesn't work:
