Invisible Lights still visible
Forums: Invisible Lights still visible
Moderator: aoktar
Re: Invisible Lights still visible
Postby caldreemn » Thu Sep 07, 2017 6:20 am
caldreemn Thu Sep 07, 2017 6:20 am
I run into this issue all the time and have been wondering what is the cause and why a 'shadow' from the light still remains when the visibility settings for a light are set to off.
Is it possible that the shadow is actually AO from the geometry of the plane, or geometry that is emitting light? I ask this because I had all the visibility settings on a light turned off and the light was clipping some geometry in my scene and it was still casting what seemed like AO on the clipped geometry...
caldreemn
Postby ralf_breninek » Thu Sep 07, 2017 7:14 am
ralf_breninek Thu Sep 07, 2017 7:14 am
Is it maybe the shadow from the light source itself?
I think I had this real world "problem" several times myself, because If you walk into a studio and light your scene you get shadows from your softboxes too.
C4D R21.207 / Octane for C4D 2020.2.4 / Watercooled 4 x EVGA Geforce RTX 2080 ti
http://www.pixelasm.com
Interface and motion graphics design for interactive interfaces and animations on TV, web, mobile and automotive from Köln / Cologne Germany
ralf_breninek
Postby fauntail » Sun Jul 29, 2018 4:35 pm
fauntail Sun Jul 29, 2018 4:35 pm
I have 3.07 and still see the light despite having followed the instructions from other users above. Anyone figure this out?
fauntail
Postby aoktar » Sun Jul 29, 2018 5:50 pm
aoktar Sun Jul 29, 2018 5:50 pm
Try latest build with opacity=0 from light tag.
Postby geoyeo » Thu Sep 23, 2021 8:30 pm
geoyeo Thu Sep 23, 2021 8:30 pm
using 2020.2.5-R2 having the same problem.
I try opacity, camera visibility but nothing works. Light is still visible on surfaces..
Any idea?
Win 11 64 | RTX 4090 | Ryzen 9 5950X | 128GB Ram
geoyeo
Postby elsksa » Thu Sep 23, 2021 10:47 pm
elsksa Thu Sep 23, 2021 10:47 pm
geoyeo wrote:using 2020.2.5-R2 having the same problem.
Any idea?
Light should be visible on surfaces, otherwise, what is the light hitting? If the light does not hit any surface, it would behave as if there was no light in the scene.
I would suggest to imagine how light behaves in the real-world or better, experience it.
Perhaps you are trying to achieve something different? Could you post a screenshot of your scene to better describe the end-goal?
elsksa
Postby geoyeo » Fri Sep 24, 2021 9:22 am
geoyeo Fri Sep 24, 2021 9:22 am
I understand the concept and of course it works like you described there is no doubt on that.
I am trying to avoid having the "square" reflection of light showing on the other objects. For eg on the sphere and on plane in this instance..
Is something like this possible?
geoyeo
Postby jayroth2020 » Fri Sep 24, 2021 6:12 pm
jayroth2020 Fri Sep 24, 2021 6:12 pm
You can try using a Rayswitch node with reflections disabled on the material, which will then not reflect the light. However, ALL of the reflections on that material will ALSO be ignored. Octane is physically accurate, and though there are some tricks here and there for some aspects, for the most part you need to manage situations like this in your scene and lighting design.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 1 EVGA RTX 3090Ti FTW3 Hybrid / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
jayroth2020
Postby funk » Fri Sep 24, 2021 6:46 pm
funk Fri Sep 24, 2021 6:46 pm
I don't use c4d, but one way to do this is to disable "visible to specular" on the texture emission node.
You'll need to find where that's done in c4d.
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby aoktar » Fri Sep 24, 2021 9:54 pm
aoktar Fri Sep 24, 2021 9:54 pm
funk wrote:I don't use c4d, but one way to do this is to disable "visible to specular" on the texture emission node.
It's in light tags
Previous
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 25 guests
Wed Apr 24, 2024 5:23 pm [ UTC ]
