Render not working
Forums: Render not working
Moderator: aoktar
Render not working
Postby Jahe » Sat Jul 24, 2021 2:17 am
Jahe Sat Jul 24, 2021 2:17 am
Hello,
I had to reinstall my TitanX (before I deinstalled everything via DDU in safe mode) and Octane doesn´t render anymore. TitanX driver is up to date.
C4D R19, Octane 3.08.2-R2.1
I can see TitanX under "devices" and it´s checked but when I want to render it says "Render Failure!!! Check console window and octane log window.".
My slower GTX 780Ti gives me Error: (Code 43) in Windows 10 device manager and its resolution is reduced to 800x600 (cant set it back anymore), that´s why I had to delete all drivers with DDU und then reinstall the TitanX again - it happened after an automatic Windows update. I disabled the 780Ti in the windows device manager for now. Issue still exist.
No way to render.
Any ideas?
It drives me crazy... and leaves me clueless.
Octane log says:
OctaneRender 3.08.2 (3080200)
CUDA error 999 on device 0: unknown error
  -> failed to link to cubin
device 0: failed to compile OSL code:
error   : Undefined reference to 'cuGeo' in 'snippets_internal'
error   : Undefined reference to 'cuParams' in 'snippets_internal'
error   : Undefined reference to 'TRANSFER_XYZ' in 'snippets_internal'
error   : Undefined reference to 'cuXyzToRgbMatrix' in 'snippets_internal'
error   : Undefined reference to 'CYAN' in 'snippets_internal'
error   : Undefined reference to 'BLUE' in 'snippets_internal'
error   : Undefined reference to 'GREEN' in 'snippets_internal'
error   : Undefined reference to 'MAGENTA' in 'snippets_internal'
error   : Undefined reference to 'RED' in 'snippets_internal'
error   : Undefined reference to 'YELLOW' in 'snippets_internal'
error   : Undefined reference to 'cu_cam' in 'snippets_internal'
error   : Undefined reference to 'cuQueues' in ' '
device 0: failed to compile module 1
error   : Undefined reference to 'cuQueues' in 'cuda_texturenode'
error   : Undefined reference to 'YELLOW' in ' '
error   : Undefined reference to 'cu_cam' in ' '
error   : Undefined reference to 'cuGeo' in 'cuda_texturenode'
error   : Undefined reference to 'cuParams' in 'cuda_texturenode'
error   : Undefined reference to 'TRANSFER_XYZ' in 'cuda_texturenode'
error   : Undefined reference to 'cuXyzToRgbMatrix' in 'cuda_texturenode'
error   : Undefined reference to 'CYAN' in 'cuda_texturenode'
error   : Undefined reference to 'BLUE' in 'cuda_texturenode'
error   : Undefined reference to 'GREEN' in 'cuda_texturenode'
error   : Undefined reference to 'MAGENTA' in 'cuda_texturenode'
error   : Undefined reference to 'RED' in 'cuda_texturenode'
error   : Undefined reference to 'YELLOW' in 'cuda_texturenode'
error   : Undefined reference to 'cu_cam' in 'cuda_texturenode'
error   : Undefined reference to 'GREEN' in ' '
error   : Undefined reference to 'MAGENTA' in ' '
error   : Undefined reference to 'RED' in ' '
error   : Undefined reference to 'cuGeo' in ''
error   : Undefined reference to 'cuParams' in ''
error   : Undefined reference to 'TRANSFER_XYZ' in ' '
error   : Undefined reference to 'cuXyzToRgbMatrix' in ' '
error   : Undefined reference to 'CYAN' in ' '
error   : Undefined reference to 'BLUE' in ' '
device 0: failed to compile module 0
Tried to access null node
Tried to access pin via an invalid ID P_MESH (111)
Tried to access null node pin
error   : Undefined reference to 'cuGeo' in ' '
error   : Undefined reference to 'cuParams' in ' '
could not pick materials, because the geometry has changed and rendering is paused
Jahe
Re: Render not working
Postby bepeg4d » Mon Jul 26, 2021 5:56 am
bepeg4d Mon Jul 26, 2021 5:56 am
Nvidia has broken the drivers some time ago under Windows, and Octane versions prior to 4.02.1 are no longer working with recent Nvidia driver versions.
You need to upgrade c4doctane to v4.05-R7, fully compatible with latest Nvidia driver.
You can find 4-05-R7 by visiting your personal Downloads area:
https://render.otoy.com/account/download_archive.php
ciao Beppe
Return to Maxon Cinema 4D
Users browsing this forum: Baidu [Spider], Google [Bot], opla and 26 guests
Fri Apr 19, 2024 12:10 am [ UTC ]
