Obj importing with jagged edges
Forums: Obj importing with jagged edges
Moderator: aoktar
Postby RouseandFable » Thu Mar 22, 2018 3:40 pm
RouseandFable Thu Mar 22, 2018 3:40 pm
Not necessarily an Octane question directly but just got this model from Turbosquid and wanted to play with it in the renderer. The obj comes in jagged like the left image. When i add a subdivision surface it becomes too smooth and neither look like the original model over grey.
Any suggestions on what i could adjust in the import settings or afterwards?
RouseandFable
Re: Obj importing with jagged edges
Postby frankmci » Thu Mar 22, 2018 5:12 pm
frankmci Thu Mar 22, 2018 5:12 pm
Your Phong angle is a bit low. Try somewhere between 30 and 35 degrees. On a model like that, you can probably even crank it up to 180 and it should look fine. You shouldn't have to use any subdivision.
- Frank
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby pinarer » Sat May 02, 2020 5:28 am
pinarer Sat May 02, 2020 5:28 am
I am having the same issue.. and not sure how to fix it, when I import my clothing into c4d as obj or fbx , in some parts i get that jagged edges, like in this example that I attached, my phong was 180 , i tried lower as well, but didint do any change. tried subdivision, that didint work neither.. if you have any idea please let me know how can I fix it..
pinarer
Return to Maxon Cinema 4D
Users browsing this forum: Google [Bot] and 24 guests
Thu Apr 25, 2024 3:45 am [ UTC ]
