IES Lights
Forums: IES Lights
Autodesk Softimage XSI (Developed by Face)
IES Lights
Postby Alul » Thu May 05, 2011 4:46 pm
Alul Thu May 05, 2011 4:46 pm
Hello Face.
I'm wondering, if its possible to setup orientation of IES emission source by softimage Spot light.
Do You think its possible to calculate IES orientation in octane by orientation of softimage light ?
Maybe IES profile export would be possible too... :D
Alul
Re: IES Lights
Postby face » Thu May 05, 2011 8:13 pm
face Thu May 05, 2011 8:13 pm
The obj-format doesn´t support IES profiles.
The next plugin version will have a support to export area lights as geometry.
Then you can plug an IES profil in Octane on it.
face
http://vimeo.com/user2509578
face
Re: IES Lights
Postby Alul » Fri May 06, 2011 6:18 am
Alul Fri May 06, 2011 6:18 am
Ok, but problem is with orientation of this IES profile. Even if you implement area light, which is very cool by the way.When i was playing with IES lights I've notice that plane rotation doesn't rotate IES. Orientation parameter is difficult to manage in octane . You simply have no idea where "center" of light distribution cone is pointing. Try to make 10 different lights with 3 IES profiles and try to operate them. I hope you understand what I mean.
Alul
Re: IES Lights
Postby DI2011 » Tue Sep 13, 2011 11:04 pm
DI2011 Tue Sep 13, 2011 11:04 pm
Face, If I understand it right I can use IES Lights with Area light from softimage since I import IES profile in octane.
That´s right? Or I don´t understand?
Regards,
Windows 7 Ultimate 64-Bit, Intel I7 980x Extreme, 6GB ram, Nvidia Geforce GTX 580
DI2011
Re: IES Lights
Postby face » Wed Sep 14, 2011 7:04 am
face Wed Sep 14, 2011 7:04 am
DI2011 wrote:Face, If I understand it right I can use IES Lights with Area light from softimage since I import IES profile in octane.
Regards,
Correct, the plugin exports the arealight as geometry and you must only setup the lights and add an IES profile in Octane.
The best choice is to select the sphere as area geometry for IES.
If you have multiple the same ligths add an diffuse node in Octane and put it in every light slot.
face
face
Return to Autodesk Softimage XSI
Who is online
Users browsing this forum: No registered users and 4 guests
Wed Apr 24, 2024 4:30 am [ UTC ]
