Page 2 of 4
Re: Octane for Softimage 3.1x
Posted:
Sat Nov 18, 2017 8:41 pm
by wireframex
I love Camaro
Posted:
Mon Nov 20, 2017 4:48 pm
by face
W-Coordinates for strands.
Posted:
Tue Nov 21, 2017 7:34 am
by face
Some other improvements...
Added roughness parameter to the diffuse material.
Changed falloff shader to match the standalone one.
Fixed the portal material wich sets the wrong attribute so the material had no effect.
The distributed raytracing parameter of the info channel kernel is changed to the combobox "Sampling Mode"
Materal mix can have a displacement texture.
New polygon side shader included to render backface polygons if the shader is pluged into the opacity port of a material.
The displacement shader will have only a texture input, so you can use the new baking shader or an image shader as input.
Images can be changed at runtime with an external program and will update automaticly.
The alpha inputs of the gradient shader are gone and an issue with the position of the marker is fixed.
Posted:
Sun Nov 26, 2017 9:27 pm
by rray
*thumbsup*
looking forward to testing portal lighting
Posted:
Tue Dec 19, 2017 11:51 am
by face
Working on the image node. It will be possible to use all image formats, which Softimage can use as image.
It will also possible to uses all image clip effects like crop, flip, rescale, color correct and so on...
face
Posted:
Tue Dec 19, 2017 9:02 pm
by wireframex
Hey Face,
What do you think about next release for SI ?
Phil
Posted:
Sat Feb 17, 2018 6:33 pm
by wireframex
Hey Face
Are you still there ?
Phil
Posted:
Mon Feb 19, 2018 6:48 pm
by face
Yes,
im here. will release a candidate the next time.
face
Posted:
Mon Apr 02, 2018 12:29 pm
by wireframex
Hey Face,
Any news for SI ?
Posted:
Mon Apr 16, 2018 7:22 pm
by wireframex
Hey Face
Please give us some news ...
Really need to know if you continue the octane dev.
Phil
