Octane for Softimage 3.1x
Forums: Octane for Softimage 3.1x
Re: Octane for Softimage 3.1x
Postby wireframex » Sat Nov 18, 2017 8:41 pm
wireframex Sat Nov 18, 2017 8:41 pm
I love Camaro :)
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 531.41 - Octane Plugin Build 2021.1.7.0
Licensed: Softimage 2012 SP1 / Lightwave 2020.2.3 / modo 16.2
wireframex
Postby face » Mon Nov 20, 2017 4:48 pm
face Mon Nov 20, 2017 4:48 pm
W-Coordinates for strands.
http://vimeo.com/user2509578
face
Postby face » Tue Nov 21, 2017 7:34 am
face Tue Nov 21, 2017 7:34 am
Some other improvements...
Added roughness parameter to the diffuse material.
Changed falloff shader to match the standalone one.
Fixed the portal material wich sets the wrong attribute so the material had no effect.
The distributed raytracing parameter of the info channel kernel is changed to the combobox "Sampling Mode"
Materal mix can have a displacement texture.
New polygon side shader included to render backface polygons if the shader is pluged into the opacity port of a material.
The displacement shader will have only a texture input, so you can use the new baking shader or an image shader as input.
Images can be changed at runtime with an external program and will update automaticly.
The alpha inputs of the gradient shader are gone and an issue with the position of the marker is fixed.
face
Postby rray » Sun Nov 26, 2017 9:27 pm
rray Sun Nov 26, 2017 9:27 pm
*thumbsup*
looking forward to testing portal lighting
Core i7 980 x GTX 980
rray
Postby face » Tue Dec 19, 2017 11:51 am
face Tue Dec 19, 2017 11:51 am
Working on the image node. It will be possible to use all image formats, which Softimage can use as image.
It will also possible to uses all image clip effects like crop, flip, rescale, color correct and so on...
face
face
Postby wireframex » Tue Dec 19, 2017 9:02 pm
wireframex Tue Dec 19, 2017 9:02 pm
Hey Face,
What do you think about next release for SI ?
Phil
Main Computer:
wireframex
Postby wireframex » Sat Feb 17, 2018 6:33 pm
wireframex Sat Feb 17, 2018 6:33 pm
Hey Face
Are you still there ?
Phil
Main Computer:
wireframex
Postby face » Mon Feb 19, 2018 6:48 pm
face Mon Feb 19, 2018 6:48 pm
Yes,
im here. will release a candidate the next time.
face
face
Postby wireframex » Mon Apr 02, 2018 12:29 pm
wireframex Mon Apr 02, 2018 12:29 pm
Hey Face,
Any news for SI ?
Main Computer:
wireframex
Postby wireframex » Mon Apr 16, 2018 7:22 pm
wireframex Mon Apr 16, 2018 7:22 pm
Hey Face
Please give us some news ...
Really need to know if you continue the octane dev.
Phil
Main Computer:
wireframex
PreviousNext
Users browsing this forum: No registered users and 8 guests
Sat Apr 20, 2024 12:33 am [ UTC ]
