Octane for Softimage 3.00 RC2 Demo/Full [Obsolete]
Posted: Sat Sep 16, 2017 6:46 am
Ok, here is the first update for V3.
Hope you enjoy,
face
FIXED:
ADDED:
CHANGED:
DOWNLOADS
INSTALLATION INSTRUCTIONS
KNOWN ISSUES
Hope you enjoy,
face
FIXED:
- ICE Particle Orientation from Euler Rotation is now correct.
- ICE Point Segment Size wasn´t used, which is fixed.
- Swapped the "Tonemap Type" under the Misc settings.
- Motionblur is now working correct with subframes.
ADDED:
- Added support for deformed motionblur.
- Added parameter for deformed motionblur subframes.
- Added parameter to enable deformed motionblur for each mesh in the mesh properies.
- Added scene for motion blur.
- Added scene for deformed motion blur.
- Added scene for texture baking.
- Added Octane materials to Get -> Material
CHANGED:
- Changed default Point Segment Size from 0.0025 to 0.025.
- Changed the kernel in the render layer scene to info channel / render layer id, to show the layer colors .
DOWNLOADS
- Softimage® 2013-2015 64bit FULL
Softimage® 2013-2015 64bit DEMO
Softimage® Project Files
Visual C++ Redistributable x64 for Visual Studio 2017
- This plugin can be installed with the usual way. Unzip the downloaded OctaneV3.zip, drag and drop the xsiaddon in the Softimage window.
You can also use the File -> Addon -> Install menu.
KNOWN ISSUES
- Motion blur and Render Layer for Pointclouds will be added in the future.
Also the possibility to use Pointclouds as instance shapes.
