Octane for Softimage 1.03 RC1 [Obsolete]
Posted: Sun Apr 10, 2016 6:30 am
Im happy to release the next version after a long time.
Hope you will like it,
face
This is a major update, so many things are fixed, added or changed.
Some things are removed and not included.
ADDED:
CHANGED:
REMOVED:
FUTURE CHANGES:
DOWNLOADS
MANUAL
INSTALLATION INSTRUCTIONS
NVIDIA DRIVER REQUIREMENTS
face
ADDED:
- New menu entries with which you can add/remove/inspect the Renderer from/to scene/pass/passes.
- New menu entry to free the GPU memory.
- The Shaderball is added again, with full support of compounds.
- Shaderball quality uses the preference settings for quality.
- New shader for the light profile is added, also the IES texture shader is changed to use the new profil shader.
CHANGED:
- The Camera check/set is completely changed.
- The Environment check/set is completely changed.
- The GPU check/set is completely changed.
- The Kernel check/set is completely changed.
- The Output shader check/set is completely changed.
- The Geometry check/set is completely changed and much faster.
- The Shader generation check/set is completely changed and much much faster.
- The Message system is updated to make it faster and to show critical warnings in red.
- The Rendersystem is completely rewritten.
- Render failure errors are now catched and shown.
- The Octane log can now be shown over a button at any time.
- The Octane node tree can be shown over a button at any time.
- Image writing will now works in mutlithreaded. This will affect the generation and the image saving.
REMOVED:
- Motion blur will no longer supported.
FUTURE CHANGES:
- Instances will included soon.
- PointClouds will included soon.
DOWNLOADS
MANUAL
- The on-line manual is available at http://render.otoy.com/manuals/Softimage/
- Please follow the installation instructions in the on-line manual.
- This version requires video driver 337.xx or higher.
