Camera mismatch...
Forums: Camera mismatch...
Camera mismatch...
Postby Kerro Perro » Thu Jun 21, 2012 11:41 pm
Kerro Perro Thu Jun 21, 2012 11:41 pm
Hi face and others,
i've not used octane in a long while and am just getting back to it with the current exporter but the camera always seems to be a little zoomed in wich is a nightmare for comping with other MR passes - and for my workflow that is a must.
I'm just using a plain old perspective camera (on a path) - that should just export correctly right? I seem remember last year it worked fine... :?
2 x Intel Xeon Quad Core @ 2.40 Ghz | Nvidia Quadro 4000 | 12 Gb RAM | Windows 7 64
Kerro Perro
Re: Camera mismatch...
Postby face » Fri Jun 22, 2012 6:18 am
face Fri Jun 22, 2012 6:18 am
Have you set the pixel ratio in the Softimage scene render options to 1?
Copy also the new aspect ratio to the render Camera.
face
http://vimeo.com/user2509578
face
Postby Kerro Perro » Fri Jun 22, 2012 12:42 pm
Kerro Perro Fri Jun 22, 2012 12:42 pm
Yeah i had the aspect ratio matching and pixel ratio at 1, i even tried an aspect ratio 1,3333 (had it at 1.7778) but if anything that seems to have zoomed it more...
I can send you a scene if you want?
Kerro Perro
Postby face » Fri Jun 22, 2012 10:41 pm
face Fri Jun 22, 2012 10:41 pm
Kerro Perro wrote:I can send you a scene if you want?
Yes, that would be helpfull.
face
face
Postby face » Sat Jun 23, 2012 7:55 am
face Sat Jun 23, 2012 7:55 am
Ok, found the problem.
You must enable the resolution.
If you don´t do this, Octane uses the resolution which is saved with your preferences.
face
face
Postby Kerro Perro » Sat Jun 23, 2012 7:07 pm
Kerro Perro Sat Jun 23, 2012 7:07 pm
Derp, can't believe i hadn't tried that... :oops: Works fine now!
Thanks a lot as always face!
Kerro Perro
Users browsing this forum: No registered users and 8 guests
Thu Apr 25, 2024 12:11 am [ UTC ]
