Maya plugin 3.06,4_11.7 use pick focus region
Forums: Maya plugin 3.06,4_11.7 use pick focus region
Moderator: JimStar
Re: Maya plugin 3.06,4_11.7 use pick focus region
Postby BK » Mon Aug 14, 2017 12:33 am
BK Mon Aug 14, 2017 12:33 am
p.jsi wrote:Hi,
Yeah with number 1 there is no problems works fine. With number .2 its seems to be shifting even if the 'use pick focus region' is unchecked/disabled.
The reason like before other cameras(which has the 'use pick focus region' checked/enabled) seems to be affecting. But solution is the same, leaving unchecked in all cameras. Just letting you know anyway.
Hey P.jsi,
Thank you !!! Would you mind sending me a video please, while we taking a look here :)
Kind Regards
bk3d
BK
Postby p.jsi » Fri Aug 25, 2017 1:24 pm
p.jsi Fri Aug 25, 2017 1:24 pm
Hi Bk,
Please follow exactly the same steps as the previous video but this time keep the auto focus unchecked. Try different area size as you do render region and the focal depth changes accordingly.
Hope this helps.
p.jsi
Postby BK » Mon Aug 28, 2017 2:46 am
BK Mon Aug 28, 2017 2:46 am
p.jsi wrote:Hi Bk,
Hope this helps.
Thank you P.jsi..
Kind Regards
bk3d
BK
Previous
Return to Autodesk Maya
Users browsing this forum: No registered users and 14 guests
Sat Apr 20, 2024 4:11 am [ UTC ]
