Cryptomatte seq rendering in 1st frame only.
Forums: Cryptomatte seq rendering in 1st frame only.
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby javierluisbravo » Wed Sep 01, 2021 7:35 pm
javierluisbravo Wed Sep 01, 2021 7:35 pm
Hi...
hope you can help me... i am rendering a sequence with cryptomatte pass turned on in render elements..
and it only renders the first frame of that pass... and then no more cryptomatte over the sequence...
the other passes are rendering fine...
what's hapenning???
javierluisbravo
Re: Cryptomatte seq rendering in 1st frame only.
Postby paride4331 » Thu Sep 02, 2021 6:57 am
paride4331 Thu Sep 02, 2021 6:57 am
Hi javierluisbravo,
do you run into the same mistake using the beauty pass?
paride4331
Postby javierluisbravo » Mon Sep 06, 2021 10:18 pm
javierluisbravo Mon Sep 06, 2021 10:18 pm
Only cryptomatte is the problem so far.
Example of 0-100 frame sequence:
Happens like this... you start rendering the sequence to hard disk... all passes in different files using the render to sequence as usual in max... First frame (frame 0) of all passes renders fine.. then.. second frame (frame 1) of all passes renders fine but cryptomatte pass is not being rendered anymore during the whole sequence...
so i have cryptomatte only frame 0... and the rest of the passes from 0-100.
Javier
javierluisbravo
Postby unpolbo » Tue Sep 07, 2021 3:34 pm
unpolbo Tue Sep 07, 2021 3:34 pm
same problem here!
unpolbo
Postby neonZorglub » Wed Sep 08, 2021 3:41 am
neonZorglub Wed Sep 08, 2021 3:41 am
javierluisbravo wrote:Hi...
what's hapenning???
Hi javierluisbravo,
Thank you for reporting this issue.
It seems to work if you enable "Save also as standard RGB image" in Render settings, Kernel Type, Cryptomatte passes setup section.
The exr files should be saved, but you'll need to delete the png/jpg .. sorry about that.
This will be fixed in the next release.
neonZorglub
Return to Autodesk 3Ds Max
Tue Apr 16, 2024 2:02 pm [ UTC ]
