self - illum
Forums: self - illum
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
self - illum
Postby Elvissuperstar007 » Tue May 25, 2021 10:26 am
Elvissuperstar007 Tue May 25, 2021 10:26 am
how to do it?
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
Elvissuperstar007
Re: self - illum
Postby paride4331 » Tue May 25, 2021 12:59 pm
paride4331 Tue May 25, 2021 12:59 pm
Hi Elvissuperstar007,
Octane Universal material is designed to follow after the workflow in the PBR model, since the Metallic material falls short of the Metallic and Roughness maps that are often derived from Substance Painter and other tools. It handles dielectric material (Diffuse and Glossy BRDF) and also Metallic material (Glossy BRDF) with assumed IOR or custom IOR for both dielectric and metallic surfaces.
paride4331
Re: self - illum
Postby Elvissuperstar007 » Tue May 25, 2021 8:05 pm
Elvissuperstar007 Tue May 25, 2021 8:05 pm
but the lights are visible on the light side of the earth
Elvissuperstar007
Re: self - illum
Postby Elvissuperstar007 » Tue May 25, 2021 9:49 pm
Elvissuperstar007 Tue May 25, 2021 9:49 pm
light appears on the light side
Elvissuperstar007
Re: self - illum
Postby paride4331 » Wed May 26, 2021 9:36 am
paride4331 Wed May 26, 2021 9:36 am
it could be help
viewtopic.php?f=9&t=68523&hilit=planetary#p344438
paride4331
Re: self - illum
Postby Elvissuperstar007 » Wed May 26, 2021 11:41 am
Elvissuperstar007 Wed May 26, 2021 11:41 am
i don't use Planetary Environment
I have an animation with a planet, which is unrealistic to do with a planet inside octane
this is geometry with customized materials, you need a function that only shines in the dark
Elvissuperstar007
Re: self - illum
Postby paride4331 » Wed May 26, 2021 1:04 pm
paride4331 Wed May 26, 2021 1:04 pm
maybe you could try using a mix textures node with a night and day texture and an animated gradient in amount.
paride4331
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 15 guests
Thu Apr 25, 2024 6:50 pm [ UTC ]
