Loading mesh speed in 3d max taboo ?
Forums: Loading mesh speed in 3d max taboo ?
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby HHbomb » Fri Oct 05, 2018 8:16 am
HHbomb Fri Oct 05, 2018 8:16 am
Hi, is loading mesh speed in 3d max taboo ?
Each time I ask I don't have any answer. Is there a solution, a workaround, is it a high priority, do we need to leave 3dsmax and switch to another software ?
It would be good to know....
HHbomb
Re: Loading mesh speed in 3d max taboo ?
Postby paride4331 » Fri Oct 05, 2018 12:31 pm
paride4331 Fri Oct 05, 2018 12:31 pm
Hi HHbomb,
Octane V4 is not stable, not for production. SDK developers are working and Octane plugin developers have to optimize Octane SDK for each Octane plugin and fixe every issue while Octane SDK is still under development. When users find issues and report it is a great help, but please, never forget Octane 3.08x is only stable version at the moment.
paride4331
Postby HHbomb » Tue Oct 16, 2018 8:55 am
HHbomb Tue Oct 16, 2018 8:55 am
For some scenes, loading meshes is longer than rendering time...
It seems to be a high priority, hope someone at Otoy is consciously aware of this.
HHbomb
Postby paride4331 » Tue Oct 16, 2018 9:12 am
paride4331 Tue Oct 16, 2018 9:12 am
HHbomb wrote:For some scenes, loading meshes is longer than rendering time...
Hi did you try that?
https://render.otoy.com/forum/viewtopic.php?f=80&t=68395&p=347944#p347944
paride4331
Postby HHbomb » Tue Oct 16, 2018 10:04 am
HHbomb Tue Oct 16, 2018 10:04 am
It is by default....
HHbomb
Postby paride4331 » Tue Oct 16, 2018 10:25 am
paride4331 Tue Oct 16, 2018 10:25 am
Hi HHbomb,
render faster than loading meshes it could happen, sometimes this can be normal.
Said that. I tested RC5 now: 32 million poligony (no instances), time loading meshes 53 seconds.
i7 32gb
What about your issue?
paride4331
Postby SergKlyosov » Tue Oct 16, 2018 10:33 am
SergKlyosov Tue Oct 16, 2018 10:33 am
Hi Paride,
I'm familiar with this setting, but can you please explain in details what is the difference between 3 options?
I know only one thing "None" option will bus loading speed if you have a lot of objects. What exactly do others do?
Cheers
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
SergKlyosov
Postby HHbomb » Tue Oct 30, 2018 10:28 am
HHbomb Tue Oct 30, 2018 10:28 am
Hi Paride, I'm back on this topic :-)
Voxelisation or loading mesh in gpu, I don't know really how it works, but the process isn't multithreaded at the begining, and if it is doable, it could cut by 10 or more loading scene time.
HHbomb
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 18 guests
Thu Apr 25, 2024 5:14 am [ UTC ]
