Displacement issue with Movable proxy
Forums: Displacement issue with Movable proxy
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby jim99 » Tue Sep 11, 2018 11:25 am
jim99 Tue Sep 11, 2018 11:25 am
Hi guys,
I am on OC 4.00 RC2-6.06 3dsmax 2016 version , I got this problem my displacement only renders when I tick off Movable proxy on mesh ?
When I turn on Movable proxy displacement is gone ? could someone help out on this issue thx
We need it for testing animation.
Jimmy
jim99
Re: Displacement issue with Movable proxy
Postby paride4331 » Tue Sep 11, 2018 12:51 pm
paride4331 Tue Sep 11, 2018 12:51 pm
Hi Jim99,
I tested your issue using 3dsMax 2016 and OC 4.00 RC2-6.06, but everything works fine.
Could you share in pm your file so I can test it, I'd like to undestand what happen to you.
paride4331
Postby paride4331 » Thu Sep 13, 2018 9:40 am
paride4331 Thu Sep 13, 2018 9:40 am
Hi Jim99,
I tested your issue, it does not happen with all the geometries.
I tried to merge the dragon in a new scene but the issue is still there.
i don't understand why that so I sent your scene to developers.
paride4331
Postby jim99 » Mon Sep 17, 2018 6:04 am
jim99 Mon Sep 17, 2018 6:04 am
Hi paride4331,
Thanks for testing this, we spend sometime testing it found the issue is to do with world scale, very weird issue... we manage to fix it by re-exporting mesh from zbrush..
Jimmy
jim99
Postby paride4331 » Wed Sep 19, 2018 7:26 am
paride4331 Wed Sep 19, 2018 7:26 am
Hi Jim99,
A workaround waiting for a fix is to use Reset XForm on the mesh.
paride4331
Postby jim99 » Tue Sep 25, 2018 1:03 am
jim99 Tue Sep 25, 2018 1:03 am
ohh thanks we will try it out
jim99
Return to Autodesk 3Ds Max
Fri Apr 19, 2024 12:40 am [ UTC ]
