Render fail
Forums: Render fail
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Render fail
Postby FabioHartmannFernandes » Tue Aug 28, 2018 1:42 pm
FabioHartmannFernandes Tue Aug 28, 2018 1:42 pm
I need some urgent help... i am in a tight schedule here
Could not initialize render, either denoise...
Thank you in advance
Tried to access attribute via invalid ID A_OUT_OF_CORE_TEX_VRAM_LIMIT (308)
can't read int/enum from static pin 'denoiserOriginalBlend' (P_DENOISER_ORIGINAL_BLEND, type PT_FLOAT) of node 'Camera imager' (NT_IMAGER_CAMERA, 00000000F72BB6D0)
CUDA error 2 on device 2: out of memory
-> failed to bind device to current thread
device 2: failed to initialize context
CUDA error 201 on device 2: invalid device context
-> failed to create link
device 2: failed to create OSL compile context:
device 2: failed to compile module 0
Tried to access attribute via invalid ID A_OUT_OF_CORE_GEO_VRAM_LIMIT (307)
can't read int/enum from static pin 'denoiserOriginalBlend' (P_DENOISER_ORIGINAL_BLEND, type PT_FLOAT) of node 'Camera imager' (NT_IMAGER_CAMERA, 00000000F72BB5B0)
can't read int/enum from static pin 'denoiserOriginalBlend' (P_DENOISER_ORIGINAL_BLEND, type PT_FLOAT) of node 'Camera imager' (NT_IMAGER_CAMERA, 00000000F72C8FF0)
Re: Render fail
Postby FabioHartmannFernandes » Tue Aug 28, 2018 2:34 pm
FabioHartmannFernandes Tue Aug 28, 2018 2:34 pm
Never mind... updated the Nvidia drivers and now it is working
Re: Render fail
Postby paride4331 » Wed Aug 29, 2018 6:40 am
paride4331 Wed Aug 29, 2018 6:40 am
Hi FabioHartmannFernandes,
Nvidia drivers version?
paride4331
Re: Render fail
Postby FabioHartmannFernandes » Wed Aug 29, 2018 9:27 pm
FabioHartmannFernandes Wed Aug 29, 2018 9:27 pm
The last one...
399.07
Fabio
Re: Render fail
Postby paride4331 » Thu Aug 30, 2018 6:11 am
paride4331 Thu Aug 30, 2018 6:11 am
are you using denoising? What about deactivating it?
paride4331
Re: Render fail
Postby FabioHartmannFernandes » Fri Aug 31, 2018 11:35 am
FabioHartmannFernandes Fri Aug 31, 2018 11:35 am
Hi Paride
I was trying to use it, but with the older driver, it was very crashy... with the new driver (399.07) works stable now.
Thx
Fabio
Re: Render fail
Postby paride4331 » Fri Aug 31, 2018 11:42 am
paride4331 Fri Aug 31, 2018 11:42 am
thanks for your info.
New 399.07 seem to be stable and work fine.
paride4331
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 5 guests
Thu Mar 28, 2024 9:22 pm [ UTC ]
