Render Layers and an alpha outline
Forums: Render Layers and an alpha outline
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby DartFrog » Thu Jul 26, 2018 9:11 pm
DartFrog Thu Jul 26, 2018 9:11 pm
I'm not sure render layers are working as intended or if my setup just isn't right. This is in all versions of the octane plugin. I'm in 4.00 XB3 - 6.02 right now. So If I have a white floor and a box in the middle of the shot, and a sphere in front of the box, and they all render on different Render IDs (with normal as the visibility mode), and I render them out as PNGs (16 bit) and load them up in photoshop, I'll get a slight outline where all the items 'touch' in my photoshop file. If I were to put like a bright red fill layer on the bottom of my stack, I'd see the red through the edges of all the layers. What is causing this, and what is the way to fix it? Is it a bug or just some unfixable thing due to the nature of the universe?
DartFrog
Re: Render Layers and an alpha outline
Postby DartFrog » Thu Jul 26, 2018 11:20 pm
DartFrog Thu Jul 26, 2018 11:20 pm
I attached some JPEGs of what I'm talking about.
I have tried PNG, Tiff, EXR, Targa (which only saves at 8 bit no matter what (??)), in all different bit depths. Some with Pre-multiplied alpha, some without, some with show environment checked, some without. etc.
I think I tried all the possible combinations I can think of for file formats and settings.
My thoughts are that when all the Layer IDs are used and layered up, it shouldn't still show pixels behind it, like it is in Photoshop currently.
Photoshop setup
Octane setup
DartFrog
Postby richardyarlett » Wed Aug 22, 2018 2:23 pm
richardyarlett Wed Aug 22, 2018 2:23 pm
My advice is to simple put the FULL RENDERED FRAME, with all three objects, on the bottom of the stack as a background, and then whatever slight antialiases errors are showing through, will disappear with the full image as a background. I know that is not the ideal answer, or the point of it, but it is very hard to get a perfect edge.
richardyarlett
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 7 guests
Fri Apr 19, 2024 1:26 am [ UTC ]
