Particle age map doesn't work?
Forums: Particle age map doesn't work?
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby senorpablo » Tue May 29, 2018 9:13 pm
senorpablo Tue May 29, 2018 9:13 pm
Trying to use particle flow to create some simple smoke. Max relies on the particle age map in a materials opacity to fade particles over time.
The particle age map doesn't seem to be compatible with Octane. I tried the baking texture and didn't have any luck.
Is there any workaround to get this working? I can't imagine how else to do any kind of fading particle without this kind of functionality.
senorpablo
Re: Particle age map doesn't work?
Postby paride4331 » Wed May 30, 2018 8:31 am
paride4331 Wed May 30, 2018 8:31 am
Hi paulforgy,
have you tried that?
paride4331
Postby senorpablo » Fri Jun 01, 2018 11:37 pm
senorpablo Fri Jun 01, 2018 11:37 pm
That doesn't work. I've tried baking texture too.
senorpablo
Postby paride4331 » Mon Jun 04, 2018 10:47 am
paride4331 Mon Jun 04, 2018 10:47 am
Hi paulforgy,
could you share (in Pm if you want) a scene with your issue please?
paride4331
Postby senorpablo » Mon Jun 04, 2018 6:34 pm
senorpablo Mon Jun 04, 2018 6:34 pm
paride4331 wrote:Hi paulforgy,
PM sent.
senorpablo
Postby pixelcan » Tue Sep 18, 2018 7:00 am
pixelcan Tue Sep 18, 2018 7:00 am
Was this ever solved?
I'm having exactly the same problem.
Need to fade particles over time(age).
Any ideas?
pixelcan
Postby senorpablo » Thu Feb 21, 2019 7:50 pm
senorpablo Thu Feb 21, 2019 7:50 pm
Any news on particle age map?
Now that there is vertex color support, this seems like it might be closer to being possible.
senorpablo
Postby paride4331 » Fri Feb 22, 2019 9:54 am
paride4331 Fri Feb 22, 2019 9:54 am
Hi senorpablo,
developers are working on it.
paride4331
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 9 guests
Tue Apr 23, 2024 6:18 pm [ UTC ]
