Automatically convert IES lights to Octane lights?
Forums: Automatically convert IES lights to Octane lights?
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby SamuelAB » Wed Aug 09, 2017 3:01 pm
SamuelAB Wed Aug 09, 2017 3:01 pm
Is there a way to automatically convert IES lights from the FBX to Octane lights?
I'm dealing with hundreds and thousands of lights (architecture models) , so this would be very appreciated. I tried last time and it did not work, I had to place all the Octane lights individually.
It would probably be easy to write a 3ds Max script that does this, but I don't write code. Thanks!
SamuelAB
Re: Automatically convert IES lights to Octane lights?
Postby paride4331 » Wed Aug 09, 2017 3:24 pm
paride4331 Wed Aug 09, 2017 3:24 pm
Hi SamuelAB,
I would not know, the only idea in mind is to use a script converter something like that:
http://www.scriptspot.com/3ds-max/scripts/multyconvertor
and convert fbx to VRay; after converting to Octane, using the Octane converter tool in the Render Stetup tools tab.
paride4331
Postby SamuelAB » Wed Aug 09, 2017 3:28 pm
SamuelAB Wed Aug 09, 2017 3:28 pm
You're saying that Octane converts Vray lights?
SamuelAB
Postby paride4331 » Thu Aug 10, 2017 5:45 am
paride4331 Thu Aug 10, 2017 5:45 am
Hi SamuelAB,
Yes for sure.
paride4331
Postby SamuelAB » Thu Aug 10, 2017 1:55 pm
SamuelAB Thu Aug 10, 2017 1:55 pm
Amazing Thank you!
SamuelAB
Postby SamuelAB » Fri Aug 11, 2017 9:36 pm
SamuelAB Fri Aug 11, 2017 9:36 pm
Hi Paride,
I was not able to install the script. When I ran it, it did not convert anything or seem to react.
I find it weird that we need to go regular light > vray light > octane light. Wondering why Octane cannot simply convert regular lights.
Please let me know if there is a special way to install this plugin (I contacted the author, but it was last updated in 2012). any alternative route would be welcomed :)
SamuelAB
Postby paride4331 » Tue Aug 15, 2017 7:01 am
paride4331 Tue Aug 15, 2017 7:01 am
Hi SamuelAB,
Octane, currently, converts vrayIES light but not photometric IES Light.
The workflow I could recommend is using V-ray converter.
Select your photometric IES Lights then:
Right mouse click> V-ray converter
When all photometric IES Light convert to vrayIES light then use Octane Coverter:
Render Set> Tools> Material Converter> Convert All
paride4331
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 14 guests
Thu Apr 25, 2024 2:36 pm [ UTC ]
