How to do SSS on Max ?!
Forums: How to do SSS on Max ?!
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby Fabrice » Mon Apr 17, 2017 6:32 pm
Fabrice Mon Apr 17, 2017 6:32 pm
I must be missing something but I try desperately to do some SSS with Octane 3 on Max 2014 without any success.
I followed all the steps of the manual https://docs.otoy.com/#3ds-max-v3-using ... ce-mediums and the only result is a glass-looking marterial.
(I'm in PMC with a specular material on teapots and cubes on a plane)
And playing with the parameters (transmission, density, absorption) seems to do just nothing! Why?
And documentation says different things at different places :
Should I set reflection to a high or low value?
Should i set directly the transmission's value or use a "float texture" node?
And all the tutorials are for C4D or standalone wich dont work the same way. It's just driving me crazy!
Is there any 3DS Max Scattering tuto somewhere?
Octane 3.04.5 + 3DS Max 2014 plugin (GTX 980 Ti + GTX 780)
Fabrice
Re: How to do SSS on Max ?!
Postby paride4331 » Tue Apr 18, 2017 7:00 am
paride4331 Tue Apr 18, 2017 7:00 am
Hi Fabrice,
with sss materials you have to use scattering or absorption nodes.
Attached a 3dsmax sss examples with materials made of diffuse or specular material.
sss.rar
(82.93 KiB) Downloaded 254 times
paride4331
Postby Fabrice » Tue Apr 18, 2017 7:02 am
Fabrice Tue Apr 18, 2017 7:02 am
Thanks Paride but could you send me the scene for Max 2014?
Fabrice
Postby paride4331 » Tue Apr 18, 2017 7:18 am
paride4331 Tue Apr 18, 2017 7:18 am
Hi Fabrice,
Here it is
sss-2014.rar
(80.51 KiB) Downloaded 187 times
paride4331
Postby Fabrice » Tue Apr 18, 2017 7:22 am
Fabrice Tue Apr 18, 2017 7:22 am
Sorry but it doesn't seems to work.
Fabrice
Postby paride4331 » Tue Apr 18, 2017 7:56 am
paride4331 Tue Apr 18, 2017 7:56 am
Hi Fabrice,
this should work
sss-2014.rar
(92.72 KiB) Downloaded 181 times
paride4331
Postby Fabrice » Wed May 10, 2017 12:26 pm
Fabrice Wed May 10, 2017 12:26 pm
Hi Paride,
still struggling with SSS...
I'd like to create some crystal sugar (on op of a chocolate sphere).
I succeeded having some nice SSS effect (thanks to your help) on the little particle pieces
but still have a big problem :
there's allways some black spot in my renderings.
And I cant get rid of this overall black tint...while the sugar should be globally white).
Maybe it's related to the very small size of the object?
(chocolate sphere is less than 1cm (o,3 inche))
Any advice?
Fabrice
Postby paride4331 » Thu May 11, 2017 9:15 am
paride4331 Thu May 11, 2017 9:15 am
Hi Fabrice,
I think it depends on using white rgb color in the enviroment slot.
Try using different light sources.
sugar.rar
(1.73 MiB) Downloaded 222 times
paride4331
Postby Fabrice » Fri May 12, 2017 7:47 am
Fabrice Fri May 12, 2017 7:47 am
Thanks Paride, very helpfull!
Fabrice
Postby Fabrice » Wed Jun 28, 2017 12:49 pm
Fabrice Wed Jun 28, 2017 12:49 pm
I'm trying now how to make a foam material (as in the references uploaded).
But I still cant figure out how to set up sss.
The color is dull and too dark, the light is weird...and render is awfull.
It look like bad wax or soap but absolutly not foam.
(I started from a sss specular material Paride sent me)
I'm lost with sss...
Any help ?
Fabrice
Next
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 11 guests
Wed Apr 24, 2024 10:19 pm [ UTC ]
