Octane export Render problems
Forums: Octane export Render problems
A forum for discussion, development and support, including subforums for discussion for various plugins for octane render and 3d the relevant animation packages
Postby Romano13 » Fri Jan 10, 2014 12:19 pm
Romano13 Fri Jan 10, 2014 12:19 pm
Hi there,
I am very new to Octane and having a little issue with exporting scene frome Cinema 4D to Octane standalone,
I can see in many tutorials that you can find a window for Octane export, and then set your preferences etc..
I can't see that tab in "Plugins" , I only have C4D Octane>>Convert Material-Live viewer window>>Octane Dialog>>>Settings
and then on the right, a tab Octane with the dialog-Setting-Live Viewer
Can anybody tell me where I can find the export tab, I am pretty sure I have installed everything, both standalone and the plugin correctly.
Many Thanks,
Romain.
Romano13
Re: Octane export Render problems
Postby abreukers » Fri Jan 10, 2014 10:05 pm
abreukers Fri Jan 10, 2014 10:05 pm
Hi Romano, I hope you're not confusing the integrated plugin with the export script as these two things are different. You can find the export script here: viewtopic.php?f=30&t=23731
abreukers
Postby vimaxus » Sun Feb 23, 2014 8:59 am
vimaxus Sun Feb 23, 2014 8:59 am
Sorry to revive this thread but I think it's something quite important and quite general.
I think especially the integrated plugin should have the possibility to export the scene in a complete manner.
The way it is now is that if a scene is worked with the integrated plugin, in order to render on x machines an animation, you have to buy:
- x times the licenses for octane (of course)
- x times licenses for all the plugins (hmm..)
- x times the licences for the 3d package (outrageous).
Or.. you have to rework everything to use a half-baked export script and all the settings in the 3d package to be able to use only machines with octane standalone as render machines.
Am I the only one that sees a BIG problem with this?
All the information is prepared for the octanerender server, it seems there wouldn't be so much work to export it in a standalone readable format with all the settings already applied.
vimaxus
Return to Plugin Discussion/Support
Who is online
Fri Jul 19, 2019 12:08 pm [ UTC ]
