How to Install on macOS Big Sur with M1 for Cinema 4D R23
Forums: How to Install on macOS Big Sur with M1 for Cinema 4D R23
Re: How to Install on macOS Big Sur with M1 for Cinema 4D R23
Postby geoyeo » Tue Mar 30, 2021 12:42 pm
geoyeo Tue Mar 30, 2021 12:42 pm
any updates on this?
I have download the latest OctaneX_PR7_Prime but no way to install to C4D R23 on MacBook Pro M1
geoyeo
Postby james_conkle » Thu Apr 08, 2021 10:47 am
james_conkle Thu Apr 08, 2021 10:47 am
Hi Beppe,
I’m doubtful you can speculate on something like this but do you think there will be Apple Silicone native versions of Octane Plugins? Or is it more realistic that it will continue to be run under Rosetta?
Asking since it seems like unless all plugins are native to the ARM architecture cinema will have to
run in Rosetta mode which sounds like it will limit performance for the DCC and plugins. It’s been encouraging to see X Particles announce they’re working towards a native plugin.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
james_conkle
Postby bepeg4d » Fri Apr 09, 2021 10:40 am
bepeg4d Fri Apr 09, 2021 10:40 am
Hi James,
the goal is to rewritten both Standalone and plugins for M1 and A15.
You cannot use Rosetta 2 on iPad Pro ;)
Happy Mac GPU rendering,
ciao Beppe
Postby ernestbelmr » Thu Apr 15, 2021 12:18 pm
ernestbelmr Thu Apr 15, 2021 12:18 pm
Hello!! Any updates on this? Is there a release date scheduled yet?
ernestbelmr
Postby geoyeo » Sat May 22, 2021 8:03 am
geoyeo Sat May 22, 2021 8:03 am
I am using C4D R23 on Mac M1 and there no way to make the plug in work...
Any walkthrough?? Rosetta etc all correct any running but can not make it work...
geoyeo
Postby geoyeo » Sat May 22, 2021 1:57 pm
geoyeo Sat May 22, 2021 1:57 pm
Still it’s impossible to install the Octane Pluginwith C4D..
Is there any walkthrough because it drives crazy all this situation since all steps made properly regarding rosetta 2
drivers, updates, files, folders everything but the plug in does not loading
geoyeo
Postby bepeg4d » Mon May 24, 2021 10:12 am
bepeg4d Mon May 24, 2021 10:12 am
PR11 is the first version supporting c4doctaneX with M1 chip.
M1 chip support is still considered experimental at this stage, and it is still working under Rosetta 2 for plugins in Big Sur, at the moment.
Please, select the Cinema 4D.app, press Command+I, to get the Info panel, and enable the **Open using Rosetta** option:
ciao Beppe
Postby geoyeo » Tue May 25, 2021 7:51 am
geoyeo Tue May 25, 2021 7:51 am
wow grazie mille Bepe. This info should be onsite regarding installation..
Finally it works..
geoyeo
Postby endreujhelyi » Tue May 25, 2021 7:13 pm
endreujhelyi Tue May 25, 2021 7:13 pm
I just bought Octane and trying to install the Octane X PR11 (Big Sur) version to my M1 mac mini, following the instructions, but it doesn't show up in Cinema 4D R23, and neither in the Security & Privacy and it's really frustrating. Can someone help me what to do? I'm not using rosetta, since it says M1 is natively supported.
endreujhelyi
Postby bepeg4d » Wed May 26, 2021 7:50 am
bepeg4d Wed May 26, 2021 7:50 am
endreujhelyi wrote:I just bought Octane and trying to install the Octane X PR11 (Big Sur) version to my M1 mac mini, following the instructions, but it doesn't show up in Cinema 4D R23, and neither in the Security & Privacy and it's really frustrating. Can someone help me what to do? I'm not using rosetta, since it says M1 is natively supported.
PR11 is the first version supporting c4doctaneX with M1 chip, and you are forced to Enable Rosetta for c4d app, or it cannot work.
Please, look at screenshot above, thanks.
ciao Beppe
PreviousNext
Return to Demo Version Questions & Discussion
Users browsing this forum: No registered users and 16 guests
Tue Apr 23, 2024 5:42 pm [ UTC ]
