DIsplacement not working
Forums: DIsplacement not working
Postby zheks22 » Thu Nov 09, 2017 8:16 am
zheks22 Thu Nov 09, 2017 8:16 am
Hey, I plug displacement node to material ( it shows displacement correctly on a material preview) but when I attach it to mesh the displacement is not on the model. I am 99% sure I am doing something this wrong way, but can't find a soilution online. Does anyone have a thoughts how to fix it ??
screens here
zheks22
Re: DIsplacement not working
Postby paride4331 » Thu Nov 09, 2017 8:37 am
paride4331 Thu Nov 09, 2017 8:37 am
Hi zheks22,
I think you're wrong unit of measurement and an incorrect position scene.
Octane Render works in meters, so importing 1 unit = 1 meter.
try the attached scene.
test.orbx
(129.36 KiB) Downloaded 263 times
paride4331
Postby zheks22 » Thu Nov 09, 2017 11:20 am
zheks22 Thu Nov 09, 2017 11:20 am
Thanks for the feedback, your scene loads displacement correctly. But when I import any geomentry it just dont work. I have checked in import optiones and its in meters, what do you mean "incorrect scene position" ?
I am bit frustrated, as I have no idea how to get this to work on an imported mesh.
zheks22
Postby paride4331 » Thu Nov 09, 2017 5:43 pm
paride4331 Thu Nov 09, 2017 5:43 pm
Hi zheks22,
try to import your geometry into my scene and compare their scale units.
I think your geometry will be much bigger than mine.
to try:
right mouse button > gemometry > mesh
right mouse button > geometry > group
connect my geometry and your to group node, then connect node group to render target.
about Geometry Import Settings see here:
https://docs.otoy.com/StandaloneH3_06/StandaloneManual3_06.htm#Standalone3_06/TheGeometryImportSettings.htm?Highlight=unit
paride4331
Postby zheks22 » Thu Nov 09, 2017 9:37 pm
zheks22 Thu Nov 09, 2017 9:37 pm
It is indeed insanely huge compared to your model. I have changed the settings to meters, but it keeps importing huge mesh.. Also when zoomed out it often looks like on screen #1. I thought it was an issue on 3d Coat side, but then I imported a mesh from C4D and it was the same, it also lost subdivision when I tried to put a displacement map on it.
It is getting realy frustrating to me, struggling with it for 2 days. but I hope I can find a solution for this issue. I have tested it on 2 computers, with Octane demo and full standalone version - same issue.
Here are some screenshots with settings, maybe that could help.
material preview works fine :
when applied to mesh it looks like this :
more settings:
zheks22
Postby zheks22 » Thu Nov 09, 2017 10:27 pm
zheks22 Thu Nov 09, 2017 10:27 pm
Ok I have made a little progress on my issue, managed to get a displacement work on C4D exported models, but mesh of the same size from 3d COAT does not get displacement. maybe it has to do with topology ?
Here are the screens.
zheks22
Postby zheks22 » Thu Nov 09, 2017 10:50 pm
zheks22 Thu Nov 09, 2017 10:50 pm
changed topology on 3d coat model now have this issue.
zheks22
Postby zheks22 » Thu Nov 09, 2017 11:12 pm
zheks22 Thu Nov 09, 2017 11:12 pm
Here is a scene file.. looking for some help here . Thanks in advance !
test2.orbx
scene with displacement issue
(398.79 KiB) Downloaded 197 times
zheks22
Return to Demo Version Questions & Discussion
Tue Apr 16, 2024 2:00 pm [ UTC ]
