Minimum version of C4D R18 is .039 but demo works with .011?
Forums: Minimum version of C4D R18 is .039 but demo works with .011?
Postby niloDanilo » Thu Aug 03, 2017 11:26 pm
niloDanilo Thu Aug 03, 2017 11:26 pm
I'm currently using the demo version of Octane (3.05.3) in Cinema4D Studio R18.011 and it's working fine. I want to buy Octane but I see that the minimum C4D version is R18.039. Can I not use Octane with my current version?
niloDanilo
Re: Minimum version of C4D R18 is .039 but demo works with .011?
Postby aoktar » Fri Aug 04, 2017 7:30 am
aoktar Fri Aug 04, 2017 7:30 am
Propably you did no delete another versions of plugin after extract and its loading R17 version of C4D. Check readme ot install notes.
Postby niloDanilo » Fri Aug 04, 2017 9:36 pm
niloDanilo Fri Aug 04, 2017 9:36 pm
Yes, I used the R17 version of Octane demo because the R18 one was not working. I forgot to mention this. Will I be able to buy Octane for Cinema4D and use the R17 one like I have done for the demo?
niloDanilo
Postby abreukers » Mon Aug 07, 2017 1:17 am
abreukers Mon Aug 07, 2017 1:17 am
Hi there, as specified, each .cdl64 file is to be used for the respective version of Cinema 4D installed in the machine.
So in your case you should only use c4dOctane-R17.cdl64 only if you are using C4D R17, otherwise you will get problems expecting features of c4dOctane-R18.cdl64
i72630QM @ 2.00GHz | 6GB RAM | 2GB GeForce GT 540M | Win7 64bit
abreukers
Return to Demo Version Questions & Discussion
Users browsing this forum: No registered users and 23 guests
Sat Apr 20, 2024 4:13 am [ UTC ]
