some questin about future
Forums: some questin about future
Postby ekanS » Tue May 04, 2010 11:13 pm
ekanS Tue May 04, 2010 11:13 pm
I have a few questions:
- with the rib import (in 1.03 beta?) will octane understand TCL scripts? (Like RIB-BOX in new renderman for maya 3)
- will octane render (and save) multiple passes - like caustic, shadow, reflection, refraction - in separate files, or multi layered image file, like EXR or PSD?
sorry if my english is too bad ;)
ekanS
ekanS
Re: some questin about future
Postby radiance » Wed May 05, 2010 8:50 am
radiance Wed May 05, 2010 8:50 am
ekanS wrote:I have a few questions:
ekanS
Hi, no not initially, and we probably won't be able to render all those passes before GPU'S are available with a lot of memory to keep all those in memory while rendering. I think in version 2.0 we will work on these areas, by then you will be able to get , although expensive, fermi GPUs with lots more memory.
Radiance
radiance
Postby redmotion » Wed May 05, 2010 12:43 pm
redmotion Wed May 05, 2010 12:43 pm
radiance, I'm curious that if its possible to tweak individual settings on shaders such as the specular strength/textures/for example, why it would not be easier just to separate this information into channels (and render each channel to a separate file). So like the clay rendering button at the top - but say, for specular - couldn't you just have everything switch off except the specular component? I can kind of do this already by just setting diffuse to black.
win 7 64 | q6600 | 4gb ram | gtx 260 [196] | driver nvidia 197.13 | SketchUp7 | Softimage 2010
win 7 64 | i5-2500k | 16gb | gtx 570 | driver 275.33 | SketchUp8 Pro
redmotion
Postby radiance » Wed May 05, 2010 2:25 pm
radiance Wed May 05, 2010 2:25 pm
redmotion wrote:radiance, I'm curious that if its possible to tweak individual settings on shaders such as the specular strength/textures/for example, why it would not be easier just to separate this information into channels (and render each channel to a separate file). So like the clay rendering button at the top - but say, for specular - couldn't you just have everything switch off except the specular component? I can kind of do this already by just setting diffuse to black.
If you would have to render these all separately it will take you a lot of time,
because you need to compute the whole render just to get accurate parts of it.
We will look for a solution to the channel output in the near future,
but i'm hoping quadro GPUs with fermi chips and 6GB ram etc will be of help here in the near future.
Radiance
radiance
Postby kubo » Wed May 05, 2010 6:26 pm
kubo Wed May 05, 2010 6:26 pm
radiance wrote:but i'm hoping quadro GPUs with fermi chips and 6GB ram etc will be of help here in the near future.
I'l have to ask for a second mortage on my house just to be able to pay for these.... lol I you put 4 wheels on top I could drive to work on it, and then maybe sell my car to pay at least one of those.... :lol:
kubo
Postby ekanS » Wed May 05, 2010 10:50 pm
ekanS Wed May 05, 2010 10:50 pm
I'm think the pass requires only remains two times more memory, but lot of rendering time. I think it becouse I found this expression in renderman DOCS:
result = SpecularDirect - SpecularDirectShadow + SpecularIndirect +
SpecularEnvironment + Ambient +
DiffuseDirect + Translucence - DiffuseDirectShadow +
DiffuseIndirect + DiffuseEnvironment + Backscattering +
Subsurface + Rim + Refraction + Incandescence
As I see, you need one piece of memory for the current pass, and a equal piece for the step-by-step incremented result.
And I'm think not every pass needs raytracing, but maybe I'm wrong.
ekanS
ekanS
Postby radiance » Thu May 06, 2010 8:34 am
radiance Thu May 06, 2010 8:34 am
ekanS wrote:I'm think the pass requires only remains two times more memory, but lot of rendering time. I think it becouse I found this expression in renderman DOCS:
ekanS
every pass needs raytracing in a physically based raytracer, we don't implement reyes rendering...
trust me, it's not as easy as this.
Radiance
radiance
Postby ekanS » Thu May 06, 2010 8:54 am
ekanS Thu May 06, 2010 8:54 am
OK, ok..
I'm just a compositor, not a programmer :)
ekanS
Postby Hawker » Thu May 06, 2010 11:35 am
Hawker Thu May 06, 2010 11:35 am
... so it's not a real multi passe engine yet :cry: :cry: :cry: :cry:
Hawker
Postby zemmuonne » Thu May 06, 2010 12:39 pm
zemmuonne Thu May 06, 2010 12:39 pm
Hawker wrote:... so it's not a real multi passe engine yet :cry: :cry: :cry: :cry:
Don't think there are pathtracers out there with render passes support, or if tere is is minimal.
zemmuonne
Next
Return to Demo Version Questions & Discussion
Who is online
Users browsing this forum: No registered users and 4 guests
Tue Apr 16, 2024 11:49 am [ UTC ]
