Pin Texture to an object that is deformed
Forums: Pin Texture to an object that is deformed
Postby briggs » Mon Apr 12, 2021 12:28 am
briggs Mon Apr 12, 2021 12:28 am
Hi All,
I am thinking of switching renderers from Redshift to Octane. Love the software so far however I cannot find an answer to one major kink in my workflow with Octane.
I use a lot of parametric objects and materials mixed with deformed objects in C4D and I can't figure out how to stick a texture like I would in Redshift or just natively in C4D.
I have looked everywhere for an example or solution to this problem with 0 luck. This one kink would stop me from using Octane so I would love to know how to fix it.
I typically like to use triplanar in redshift but it has an option to stick the texture before deformation. There is no equivalent in Octane?
I find it hard to believe that there is no fix for this so if anyone could shed some light it would be greatly appreciated.
briggs
Re: Pin Texture to an object that is deformed
Postby bepeg4d » Mon Apr 12, 2021 6:30 am
bepeg4d Mon Apr 12, 2021 6:30 am
have you tried to keep the c4d mat projection to UVW, and use the c4d Sticky Texture tag?
If it doesn’t work, please post a simple example scene that shows the issue, thanks.
ciao Beppe
Postby briggs » Mon Apr 12, 2021 11:33 am
briggs Mon Apr 12, 2021 11:33 am
Thanks Beppe, that was the first thing I tried but it's when you introduce triplanar into the mix that the issue arises.
I have provided a link to a sample file, thanks!
https://shared-assets.adobe.com/link/87 ... 49c70543c6
briggs
Postby CooteJam » Thu Jan 26, 2023 2:23 pm
CooteJam Thu Jan 26, 2023 2:23 pm
Just having the same problem, the pin tag works if the material is simple but if it is a mix or composite material it doesnt work and the texture slides all over the object.
CooteJam
Postby bepeg4d » Fri Jan 27, 2023 7:26 am
bepeg4d Fri Jan 27, 2023 7:26 am
Oops, forgot this discussion!
Better to have proper unfolded uvs with deformed geometry.
With complex material, you can use the Baking camera to simplify it, and have proper uv-mapped textures to be sticked and deformed.
ciao,
Beppe
Return to Demo Version Questions & Discussion
Users browsing this forum: Google [Bot] and 24 guests
Thu Apr 25, 2024 10:23 am [ UTC ]
