Octane for Houdini: I can't make a dark room
Forums: Octane for Houdini: I can't make a dark room
Postby stepharamburu » Sat Nov 27, 2021 7:17 am
stepharamburu Sat Nov 27, 2021 7:17 am
Hello. I have a problem trying to make a dark room in Houdini. As you can see in the photo, inside a room with no windows or doors, it still looks bright. It is as if the light of the external sun passes through the walls.
stepharamburu
Re: Octane for Houdini: I can't make a dark room
Postby juanjgon » Sat Nov 27, 2021 9:02 am
juanjgon Sat Nov 27, 2021 9:02 am
Can you please share the rendered image and the scene?
juanjgon
Postby bepeg4d » Sat Nov 27, 2021 9:08 am
bepeg4d Sat Nov 27, 2021 9:08 am
stepharamburu wrote:Hello. I have a problem trying to make a dark room in Houdini. As you can see in the photo, inside a room with no windows or doors, it still looks bright. It is as if the light of the external sun passes through the walls.
Probably the Kernel is set to AO Direct Lighting preview mode.
Set the Kernel to Path Tracing or PMC for a correct result.
ciao,
Beppe
Postby stepharamburu » Sat Nov 27, 2021 12:26 pm
stepharamburu Sat Nov 27, 2021 12:26 pm
Hi! Yes, using Path Tracing instead of Direct Light, solves the problem... thanks!
stepharamburu
Return to Demo Version Questions & Discussion
Users browsing this forum: No registered users and 26 guests
Thu Apr 25, 2024 9:20 pm [ UTC ]
