Please help,
how export real 32bit EXR pictures from picture viewer? From Live Viewer, yes I have real 32bit EXR, but from Picture Viewer not, look like 8 bit after opening in Photoshop, please look at the image. https://ibb.co/mq2xMn
aoktar wrote:select float() framebuffer and save as exr.
aoktar wrote:You made me have to test it again. I cannot see any differences between both of methods. See my test. How do you really open and compare? I'm using default settings of Octane render settings.
PiotrRymer wrote:of course, you can't see any differences before you start to change exposure in 32bit exr files, so - with correct rendered 32bit file these highlights can be recovered by exposure, in 8bit mode this is impossible.
aoktar wrote:PiotrRymer wrote:of course, you can't see any differences before you start to change exposure in 32bit exr files, so - with correct rendered 32bit file these highlights can be recovered by exposure, in 8bit mode this is impossible.
I and you missed this, you can't compare float(tonemapped) vs. exr saved from LV. Float(tonemapped) buffer is clamping values, you should use Float butter.
aoktar wrote:This one
do you have any idea how to save correctly from native Picture Viewer in Cinema file in 32bit exr?
Return to Demo Version Questions & Discussion
Users browsing this forum: No registered users and 26 guests
