Gradual noise dissipation
Forums: Gradual noise dissipation
Postby coilbook » Tue Aug 22, 2017 9:12 pm
coilbook Tue Aug 22, 2017 9:12 pm
Hi anyway we can have a spinner called border width so we can have gradual noise dissipation where mesh ends. Good for puddles masks etc. So noise does not get cut by mesh edges Thank you
coilbook
Re: Gradual noise dissipation
Postby mojave » Tue Aug 22, 2017 9:22 pm
mojave Tue Aug 22, 2017 9:22 pm
You can achieve this by using a Multiply texture node with your noise as one of the inputs and a greyscale mask you'd like to use to delimit your edges as the second one.
mojave
Postby coilbook » Wed Aug 23, 2017 12:51 am
coilbook Wed Aug 23, 2017 12:51 am
mojave wrote:You can achieve this by using a Multiply texture node with your noise as one of the inputs and a greyscale mask you'd like to use to delimit your edges as the second one.
hi thank you
we jsut thought if you guys can do it procedurally where noise map can detect edges like dirt map so we dont have to deal with masks and mapping thank you
coilbook
Postby calus » Wed Aug 23, 2017 9:37 am
calus Wed Aug 23, 2017 9:37 am
hi thank you
You just need to use the dirt node as the mask so everything is procedural...
Pascal ANDRE
Maya 2019, Windows 7, 128 GB RAM
4x GTX 1070, driver 430.39
calus
Postby coilbook » Wed Aug 23, 2017 12:57 pm
coilbook Wed Aug 23, 2017 12:57 pm
calus wrote:
hi thank you
Thank you
unfortunately dirt shows up when other meshes get close to it. i wish dirt worked on sub object level so other objects in close proximity wont create dirt on the object with a dirt map.
Please otoy add an option where dirt works on sub object level only
coilbook
Return to Commercial Product News & Releases (Download here)
Fri May 29, 2020 9:26 pm [ UTC ]
