Glass refraction with bottle+water
Forums: Glass refraction with bottle+water
Postby FLXmedia » Fri Jul 07, 2017 2:49 pm
FLXmedia Fri Jul 07, 2017 2:49 pm
Hello guys,
since i am new to octane, i find myself in a tricky situation, where i need to render a bottle of gin.
With the standard Cinema4D physical renderer, the refraction in my bottle (and on the edge) looks much more realistic than my rendering on Octane.
I attached three images to this post. 1. is the original Cinema4D Physical Render. (Water index 1,33)
2. is the Octane render with a standard glass material from the Live DB (Index:1,65) and a water material at Index: 1,01.
3. is the Octane render with the same glass material (Index: 1,65) and the water material at Index 1,3.
4. a real picture showing the desired refraction.
Can you please look at them and tell me, what i did wrong?
The bottle itself is constructed with a lathe-object with the liquid being another lathe object intersecting with the bottle.
Is this modelling technique wrong?
Thanks in advance for your help and time!
Greets,
Felix
FLXmedia
Re: Glass refraction with bottle+water
Postby bepeg4d » Fri Jul 07, 2017 3:17 pm
bepeg4d Fri Jul 07, 2017 3:17 pm
difficult to say with your screenshot, there is not too much to reflect/refract right now compared with your reference, but in OctaneRender, you need that the liquid is slightly overlapping the glass, to have the correct effect.
Or modelling in a different way, like explaned in the picture below:
ciao beppe
Postby FLXmedia » Fri Jul 07, 2017 3:33 pm
FLXmedia Fri Jul 07, 2017 3:33 pm
bepeg4d wrote:Hi,
ciao beppe
Hi beppe,
thanks for your help.
I am looking for the refraction especially on the back label refracting to the bottle sides. I modelled it with a small overlap.. so you think i should model the liquid completely inside the glass?
Thank you!
FLXmedia
Postby nuno1980 » Fri Jul 07, 2017 4:15 pm
nuno1980 Fri Jul 07, 2017 4:15 pm
Hi, FLXmedia :)
If you deserve "real life" then all specular materials must have dispersion. ;)
-- Glass settings:
reflection - 0.930
transmission - 1.000 (greyscale color)
ior - 1.509* (it's ior dispersed and the original ior is 1.53)
dispersion coefficient - 0.006*
rest default
-- Water at +/- 18 ºC settings:
reflection - 0.930
transmission - 0.998 (greyscale color)
ior - 1.323* (ior dispersed and original ior 1.333)
dispersion coefficient - 0.003*
rest default
* - see 2 formulas (convert from "abbe number" to "dispersion cofficient (= B)"; calculate from original refractive index (ior) to
ior dispersed) ---> viewtopic.php?f=25&t=61949#p316752 (look my message on Jun 24, 2017 11:37 am UTC)
--> I'm recommended you use PMC kernel for almost real life, if your videocard is very fast (eg: GTX 780, 980, 980Ti...). ;)
NOTE: I'm sorry for bad english due to mute ;)
[email protected]
16GB [email protected]
ASUS Z97-Pro Gamer
EVGA GF GTX 980 Ti SC+ 2.0 :D
SSD OCZ RD400 0.5TB
HDDs 1TB SATA2 and 3TB SATA3.
LG BD-RE BH16NS40
PSU 1 kW
LCD-LED monitor 24" BenQ XL2411P NEW! :D
nuno1980
Postby nuno1980 » Fri Jul 07, 2017 7:48 pm
nuno1980 Fri Jul 07, 2017 7:48 pm
LAST EDIT: water only (look my previous message) or
-- Water with 45% alcohol at 20 ºC settings:
reflection - 0.930
transmission - 0.982 (greyscale color)
ior - 1.350 (ior dispersed and original ior 1.360)
rest default
[email protected]
ASUS Z97-Pro Gamer
SSD OCZ RD400 0.5TB
LG BD-RE BH16NS40
PSU 1 kW
nuno1980
Postby FLXmedia » Fri Jul 07, 2017 9:04 pm
FLXmedia Fri Jul 07, 2017 9:04 pm
nuno1980 wrote:Hi, FLXmedia :)
-- Glass settings:
reflection - 0.930
rest default
reflection - 0.930
rest default
Wow, thanks for your help man! I'm using the PMC kernel, since we are working with a 980ti.
But, have you done something similar before? How do i have to model? Slight overlap in glass/liquid or small gap between that?
Thank you very much for your help!!
FLXmedia
Return to Commercial Product News & Releases (Download here)
Thu Jun 04, 2020 10:00 pm [ UTC ]
