How to export from Rhino to Max Properly
Forums: How to export from Rhino to Max Properly
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby tonycho » Fri Nov 11, 2011 8:56 am
tonycho Fri Nov 11, 2011 8:56 am
Hi Guys, need help :D
how to export from Rhino to max properly, I try to convert to obj but when I open in max
it got wrong. in max viewport its looks fine, but when I render it to octane all wrong.
I try to making new object from max and replace it ( hand railing escalator) but I dont know why the polygon still broken
Thank you very much Guys :)
here is the picture
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
tonycho
Re: How to export from Rhino to Max Properly
Postby tonycho » Fri Nov 11, 2011 9:39 am
tonycho Fri Nov 11, 2011 9:39 am
Hi Guys, I have found the answer :oops: (sorry)
Power Translator 8 (npower) just try the demo and all good
tonycho
Postby gabrielefx » Fri Nov 11, 2011 12:09 pm
gabrielefx Fri Nov 11, 2011 12:09 pm
the best translator is Deep Exploration.
you export from Rhino in step (stp) format or acis (sat)
Don't export the entire scene in one step! Divide the scene in layers and save separate files. Please, check always the normals.
Then import (open) the files in Deep Exploration. You can choose two import methods: Alternative (best for flat surfaces) Recommended (best for smooth surfaces)
Choose the tessellation, try it yourself with parameters.
Then export from Deep Exploration directly in Max. First you have to choose the Max you have installed. The first time DE will try to open Max and then Max will crash. Close DE, reload it and save the file again. Max will be opened in the background.
With DE you can open directly Max files.
Regards.
gabrielefx
Postby tonycho » Sat Nov 12, 2011 7:32 pm
tonycho Sat Nov 12, 2011 7:32 pm
wow thanks gabriele, its new info :D
tonycho
Postby Refracty » Sat Nov 12, 2011 7:37 pm
Refracty Sat Nov 12, 2011 7:37 pm
Tonycho, the Rhino tesselation is pretty good.
You can assign a per object tesselation in the object preferences in Rhino and check the meshes in realtime.
Pretty fast and save. I export Rhino to Octane often and never got big trouble.
You can send me a Rhino scene to check if you want.
Cheers
Nando
Refracty
Postby tonycho » Sun Nov 13, 2011 3:36 pm
tonycho Sun Nov 13, 2011 3:36 pm
Hi Refracty, thanks for your solution
last day I try to export from rhino to max using 3ds file
but now everything alright. and I dont have rhino yet.
want to try in next month :D
tonycho
Return to Resources and Sharing
Users browsing this forum: No registered users and 52 guests
Thu Apr 25, 2024 7:37 am [ UTC ]
