Page 4 of 5
Re: Using medium nodes
Posted:
Mon Mar 12, 2012 8:43 am
by a.boeglin
Yes I understand that, the only problem is that the roughness also changes the transparency glossiness. If I move the roughness closer to 0, my wax looks like glass. It would be best to separate the transparency roughness from the reflection roughness. Or is there a way to do it with a mix material ? I didn't seem to make it work as the mix material doesn't seem to allow me to add a reflection layer as the blend material would in vray, which is kind of a lack to simulate wood materials or car paint material with multi layered coats.
Another point, I think namings are a bit confusing in octane. Specular material for a transparent material does not make a lot of sense to me. Why not calling it transparent material ?
Lumière Volumique
Posted:
Sun Nov 11, 2012 9:25 pm
by jauffrey
roeland wrote:Hi,
You can use the same types of emission node as you would use for a regular emitter.
Roeland
hello jai a little problem on light volume it does appear that pass questions why i did wrong, I do not understand
forgive me for my english google
thank you
Posted:
Sun Nov 11, 2012 11:58 pm
by roeland
Your screenshot doesn't show any settings, so I can't tell if anything is wrong here. What are the values for the inputs to the specular material and the scattering medium?
Roeland
Posted:
Mon Nov 12, 2012 7:38 pm
by jauffrey
roeland wrote:Your screenshot doesn't show any settings, so I can't tell if anything is wrong here. What are the values for the inputs to the specular material and the scattering medium?
Roeland
Hi, excuse me here is the detail of the parameter
thank you again
Posted:
Mon Nov 12, 2012 8:20 pm
by roeland
For fog you need a low scattering value, and no absorption. Set absorption to 0, scattering to 1, and the scale input, which is multiplied with these two numbers, to a low value like 0.1.
Roeland
Posted:
Mon Nov 12, 2012 10:59 pm
by jauffrey
roeland wrote:For fog you need a low scattering value, and no absorption. Set absorption to 0, scattering to 1, and the scale input, which is multiplied with these two numbers, to a low value like 0.1.
Roeland
Merci beaucoup mais alors ces très tres long
mais sur 3gtx 590
Posted:
Mon Nov 12, 2012 11:00 pm
by jauffrey
Roeland
Thank you very much but then these very very long
but 3gtx 590
Posted:
Sun Dec 09, 2012 5:55 pm
by Joely-Bird
A question on using Medium Nodes... Is there a work around for getting a nice sss effect on single plane geometry? typically this is how trees are modelled & giving all the leaves thickness would create huge meshes, but without doing that medium nodes don't work on single polys.
So any tips & tricks?
Posted:
Sun Dec 09, 2012 9:29 pm
by roeland
No, sub surface scattering requires some thickness at the moment. For single plane geometry you can have translucency if you set a transmission value on a diffuse material.
Roeland
Using medium nodes
Posted:
Tue Jun 02, 2015 12:41 pm
by LesterPn
hey i have a question... if i click the deform button and select "textures" my
list of "terrain textures" is empty.. any suggestions?
