Is it possible to animate vectron values in its script?
Forums: Is it possible to animate vectron values in its script?
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby foliohattu » Tue Jun 23, 2020 2:05 pm
foliohattu Tue Jun 23, 2020 2:05 pm
im Wondering if its possible to animate vectron script values by adding a key framable slider or altering its script to say that in x number of frames the number should be x ?
Trying to think a way to animate following numbers on menger sponge boolen.
Mainly the 2.1 and 3.2
vector a = mod( p*s, 2.1 )-1.0;
s *= 3.0;
vector r = abs(1.0 - 3.2*abs(a));
Does anyone know if this is possible?
foliohattu
Re: Is it possible to animate vectron values in its script?
Postby bepeg4d » Thu Jun 25, 2020 7:17 am
bepeg4d Thu Jun 25, 2020 7:17 am
you can use the time parameter, please have a look at this example:
 #include "octane-oslintrin.h"
shader OslGeometry(
    int Iterations = 10,
    float Power = 2.0,
    float Bailout = 20,
    output _sdf c = _SDFDEF)
    vector pos = P;
    float power = Power;
    float w = fmod(_wipes(), 300.0) / 300.0;
    w += time / 300.0;
    power = w * 5 + 5.0;
   vector z = P;
   float dr = 1.0;
   float r = 0.0;
   for (int i = 0; i < Iterations ; i++) {
      r = length(z);
      if (r>Bailout) break;
      // convert to polar coordinates
      float theta = acos(z[2]/r);
      float phi = atan2(z[1],z[0]);
      dr =  pow( r, power-1.0)*power*dr + 1.0;
      // scale and rotate the point
      float zr = pow( r,power);
      theta = theta*power;
      phi = phi*power;
      // convert back to cartesian coordinates
      z = zr*vector(sin(theta)*cos(phi), sin(phi)*sin(theta), cos(theta));
      z+=pos;
   c.dist = 0.5*log(r)*r/dr;
ciao Beppe
Postby AtomicNixon » Tue May 10, 2022 6:00 pm
AtomicNixon Tue May 10, 2022 6:00 pm
Could you tell me the purpose of this line, and what the function _wipes() does, is for? Having real trouble getting this to work properly. More info on how the time variable works is very much needed. Also, any other undocumented variables we should know about?
AtomicNixon
Return to Resources and Sharing
Users browsing this forum: No registered users and 18 guests
Fri Mar 29, 2024 6:20 am [ UTC ]
