Cherry tree?
Forums: Cherry tree?
Cherry tree?
Postby Jorgensen » Thu Jan 26, 2017 8:00 pm
Jorgensen Thu Jan 26, 2017 8:00 pm
hi
does anyone know of a cherry tree in good quality that can be used with octane?
i need to create a scene where i have several cherry trees, and i thought i a combination with scatter (sketchup) and a tree in a good quality could do the job but....
i have bought this tree https://www.turbosquid.com/FullPreview/Index.cfm/ID/761493, but it seems that the obj file is just on big object and so i can't use it in octane :-/
any tips?
thanks
jorgensen
Jorgensen
Re: Cherry tree?
Postby Jasonr » Thu Jan 26, 2017 9:25 pm
Jasonr Thu Jan 26, 2017 9:25 pm
Why don't you edit the file in 3dmax?
Remove the base and keep the tree. Export the file again as obj and load in Octane?
Guess this will work...
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Jasonr
Re: Cherry tree?
Postby Jorgensen » Fri Jan 27, 2017 1:47 pm
Jorgensen Fri Jan 27, 2017 1:47 pm
hi jasonr
i just tried to open the tree in max, but i can't figure out how to select for example all leaves - or all small branches :-/
it seems that they are not grouped or on a specific layer. i can fine select the trunk and the larger branches as one object, detach and export....
jorgensen
Jorgensen
Return to Resources and Sharing
Who is online
Users browsing this forum: No registered users and 25 guests
Tue Apr 23, 2024 3:07 pm [ UTC ]
