Octane beginner question
Forums: Octane beginner question
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby jochen.ulmer » Sat Nov 05, 2016 11:54 am
jochen.ulmer Sat Nov 05, 2016 11:54 am
Hello,
I am a new user from Octane. I try to make a material like this "silver color" on the picture. Can help me someone what settings I should use to make this?
Regards,
Jochen
jochen.ulmer
Re: Octane beginner question
Postby bepeg4d » Sat Nov 05, 2016 3:54 pm
bepeg4d Sat Nov 05, 2016 3:54 pm
Hi Jochen,
a first attempt of plastic to play with:
without bump
and with bump
You have to correct the scale base on your object and adjust here and there some values:
PlasticMat.orbx
(4.68 KiB) Downloaded 141 times
ciao beppe
Postby jochen.ulmer » Sat Nov 05, 2016 4:03 pm
jochen.ulmer Sat Nov 05, 2016 4:03 pm
Wow it looks very cool. Thank you very much for the help. Is it possible that I open this material in Cinema 4D with Octane Plugin?
jochen.ulmer
Postby bepeg4d » Sat Nov 05, 2016 5:35 pm
bepeg4d Sat Nov 05, 2016 5:35 pm
Yes sure, in Live Viewer, choose Import ORBX from the File menu:
ciao beppe
Postby jochen.ulmer » Sat Nov 05, 2016 6:15 pm
jochen.ulmer Sat Nov 05, 2016 6:15 pm
Cool thank you!
jochen.ulmer
Postby jochen.ulmer » Mon Nov 07, 2016 9:31 pm
jochen.ulmer Mon Nov 07, 2016 9:31 pm
Is it possible to make the Material a little bit darker?
jochen.ulmer
Postby bepeg4d » Tue Nov 08, 2016 9:53 am
bepeg4d Tue Nov 08, 2016 9:53 am
Hi jochen,
just add another color correction node between the clamp node and the diffuse pin and reduce its power as needed.
ciao beppe
Postby jochen.ulmer » Sat Nov 19, 2016 12:09 pm
jochen.ulmer Sat Nov 19, 2016 12:09 pm
Thank you very much for your help.
jochen.ulmer
Return to Resources and Sharing
Tue Feb 18, 2020 6:36 pm [ UTC ]
