configuration Graphic Cards
Forums: configuration Graphic Cards
Postby daniel.quentin.161 » Sat Jan 03, 2015 10:25 am
daniel.quentin.161 Sat Jan 03, 2015 10:25 am
Hello, I have at present a config with gtx 780 ti 3Go of ram, and I intend to buy to myself one Titan 6 GO of ram, Octane will block(surround) me you he(it) in 3 go for textures, which I have to set as card(map)? To note that I also have a GTX 660 TI but that I did not put in my case? It is worth it he(it) saddens her(it)? Thank you
i7 3820 + asus sabertooth x79 + 16 go ram + GTX 780 TI + ssd ocz vertex3 112 go + 2 Seagate (1 TO + 2 TO) + wacom intuos a4 xl
daniel.quentin.161
Re: configuration Graphic Cards
Postby FooZe » Sun Jan 04, 2015 10:43 pm
FooZe Sun Jan 04, 2015 10:43 pm
Hi Daniel,
If you have a 3GB 780 and a 6GB titan rendering, you will have a 3GB scene size limit.
Your scene size in octane is equal to the smallest of your cards. You can always just only tick the 6GB for rendering when your scene grows to more than 3GB and then your scene size will be 6GB. So there is no down side to having more GPU's in your system, you can always turn them off in the octane options and then they will not be used by octane.
So use them all for small scenes, and as your scene grows and no longer fits on your small GPU's then turn them off in octane.
I hope that makes sense?
FooZe
Postby rappet » Sun Jan 04, 2015 11:36 pm
rappet Sun Jan 04, 2015 11:36 pm
Hi Fooze,
I was trying to find a thread about network rendering and GPU configuration, but I can not find it.
... in addition of this thread I am wondering how it works when want to disable the small GPU of a network render slave?
Now I choose 'all' gpu, but how to assign only the big GPU of a slave?
Greetz,
@Daniel, sorry to hike your thread a little :oops:
rappet
Postby FooZe » Sun Jan 04, 2015 11:41 pm
FooZe Sun Jan 04, 2015 11:41 pm
You need to re-run the install daemon batch file that comes with the standalone and select only the GPU's you want.
It should allow you to enter a list like 1,3. Then close the slave and re-run it using the run installed slave batch file.
You may need to run the standalone to find out what order the GPU's are being reported to Octane so you can pick the right ones.
FooZe
Postby rappet » Sun Jan 04, 2015 11:43 pm
rappet Sun Jan 04, 2015 11:43 pm
Hi Fooze,
Thanx for your quick and clear response. I will try that and I am sure I am gonna succeed :(
rappet
Postby daniel.quentin.161 » Mon Jan 05, 2015 1:11 pm
daniel.quentin.161 Mon Jan 05, 2015 1:11 pm
ok thank you, so I can put a titan for the record I'm waiting for the moment a power of 1,000 watts to put my 660 ti for the preview, I hope that I will see a change in waitting have the money for titan.
daniel.quentin.161
Return to Resources and Sharing
Who is online
Users browsing this forum: No registered users and 54 guests
Thu Apr 25, 2024 4:52 am [ UTC ]
