Doing Everything (Well Almost) In Octane Standalone
Forums: Doing Everything (Well Almost) In Octane Standalone
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby Jaberwocky » Sun Sep 28, 2014 2:51 pm
Jaberwocky Sun Sep 28, 2014 2:51 pm
As the heading suggest's . This morning i tried to answer the question
Apart from creating the mesh, can you do everything else in Octane Standalone ?
Well , it turns out you can....whether you'd want to though is a whole different matter ! ;)
I started by created a spacecraft panel and UV mapped it.
I then Imported the mesh into Octane and started layering up and positioning the various diffused and Bump Maps on the surface.
The result is attached.
One thing I found out is that you can Layer up Bump maps.I also Changed The Gamma settings on various layers to help with the strength of the bumps and the colors of the diffused maps to pass through the layers.
I've attached the .Orbx File if anyone want's to have a play !
Jaba
It does make you wonder if a Lua Script for importing and stacking layers directly within Octane might be a good idea !
space craft paneling.orbx
(395.39 KiB) Downloaded 106 times
Jaberwocky
Return to Resources and Sharing
Users browsing this forum: MNIB and 2 guests
Fri Jan 24, 2020 5:57 pm [ UTC ]
