Peter Guthrie HDRI
Forums: Peter Guthrie HDRI
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Peter Guthrie HDRI
Postby thefishnut » Sun Sep 07, 2014 11:58 am
thefishnut Sun Sep 07, 2014 11:58 am
I am having trouble adjusting a HDRI that I have purchased from Peter Guthrie. My hope was that it would work out of the box. But I find it is instantly so bright that the screen is blanketed white. I have played around with the HDRI texture power and the environment power, but cant find a happy balance. Is there a recommended base setting when using Peter Guthries HDRI's? I am using a texture environment with the HDRI in the texture node as a RGB image.
Many Thanks.
Win 8 64 | 2 x Geforce GTX780 6gb | i7 4790k | 32GB
thefishnut
Re: Peter Guthrie HDRI
Postby FooZe » Mon Sep 08, 2014 3:57 am
FooZe Mon Sep 08, 2014 3:57 am
Using a texture environment with the HDRI loaded in as a RGB Image is the normal way.
Are you using the standalone? What do the specs say for the image eg: 6250x3125 pixels, 96 bpp RGB HDR, 305175 KB.
Is is a .hdr file?
Have you played with the textures gamma in octane? (default is 2.2)
FooZe
Postby Seekerfinder » Mon Sep 08, 2014 5:12 am
Seekerfinder Mon Sep 08, 2014 5:12 am
Also, check your camera exposure & ISO settings. Just perhaps you messed with them in the scene before trying this HDRI.
Best,
Seeker
Seekerfinder
Postby mbetke » Mon Sep 08, 2014 6:27 am
mbetke Mon Sep 08, 2014 6:27 am
I had the same problems with them. Had to use Gamma 1.0 in the environment slot plus lowering Iso low to 5 sometimes.
I experienced it with other HDR images too and using the 3dsmax plugin there seems no way to set the image up properly while loading (the little white and black point bix which appears if you click it).
I ended up using the CG-Source skies (http://www.cg-source.com/products_hdris ... at=hdrisky).
They work very well out of the box and you can download low-res versions before buying.
Pure3D Visualisierungen - Germany
Sys: Intel X5690, 128GB RAM, 2x Titan RTX, Windows 10 Pro x64, 3ds Max 2019
mbetke
Postby sdwhitton » Mon Sep 08, 2014 12:20 pm
sdwhitton Mon Sep 08, 2014 12:20 pm
Peter Guthrie's HDRIs are very bright I find
What I do is open then in photoshop, and add an exposure layer over the top, bring the exposure down a touch
I also resize them to I dunno, 4000 pixels wide
then save this out as a new version
I think he mentions this in his 'faqs'
workstation well past its sell-by-date, Vista 64 bit (!) with a pitiful amount of RAM, re-invigorated with a GX 590
3ds Max Design 2011 (have 2013 but can't be bothered to re-do all the UI), CS5, and that free z-brush program, whatever it's called
sdwhitton
Postby sdwhitton » Mon Sep 08, 2014 12:22 pm
sdwhitton Mon Sep 08, 2014 12:22 pm
also, once you've made your own re-exposed hdr, try then playing with the gamma in Octane, as this affects the strength / definition of the shadows quite a lot
cheers!
sdwhitton
Postby enigmasi » Mon Sep 08, 2014 1:32 pm
enigmasi Mon Sep 08, 2014 1:32 pm
don't change iso, keep iso 100, gamma 1 to see result better
peter guthrie hdri's very bright, try to keep image's gamma under 1, and very low power
enigmasi
Postby mbetke » Tue Sep 09, 2014 6:48 am
mbetke Tue Sep 09, 2014 6:48 am
If I do this the shadows are nearly gone.
mbetke
Postby thefishnut » Thu Sep 11, 2014 11:08 am
thefishnut Thu Sep 11, 2014 11:08 am
Thanks guys.
enigmasi wrote:don't change iso, keep iso 100, gamma 1 to see result better
Why do you say that enigmasi? Changing the gamma to 1 and the iso to about 5 does seem to work. Unless I am missing something. Will changing the iso effect other things I haven't though of?
thefishnut
Postby enigmasi » Thu Sep 11, 2014 12:06 pm
enigmasi Thu Sep 11, 2014 12:06 pm
I meant keep default settings for CameraImager. Use low gamma for hdri, like under 1 even, and very low power 0.0... because his hdri's are very bright
enigmasi
Return to Resources and Sharing
Wed Aug 21, 2019 2:35 am [ UTC ]
