Problem export from max to obj
Forums: Problem export from max to obj
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby stanvisual » Tue Jul 09, 2013 12:45 am
stanvisual Tue Jul 09, 2013 12:45 am
I am a new user, i try to export a file with lighting and material from max to obj. but i found that the file become one object when opened in standalone. There are no material in it ,is that correct?
stanvisual
Re: Problem export from max to obj
Postby FooZe » Tue Jul 09, 2013 1:06 am
FooZe Tue Jul 09, 2013 1:06 am
Hi Stan,
I think there may be some export setting not correct.
If you are using the inbuilt 3ds max .obj exporter, make sure "use material" and "create mat-library" are on (http://docs.autodesk.com/3DSMAX/15/ENU/ ... d30e521842)
Then make sure if you move the .obj, that you also move the .mtl file with the same name.
However, your best option is to use the unofficial 3ds max export script: viewtopic.php?f=27&t=7572
Chris.
FooZe
Return to Resources and Sharing
Tue Jan 19, 2021 5:17 am [ UTC ]
