Page 4 of 7
Re: Softimage to Octane exporter
Posted: Sun May 02, 2010 6:45 pm
by face
radiance wrote:
face wrote:I´ve found a other stuff that can be changed. The render size. Usefull for a quick render too.
A option is to give the user a preset. 1/1 1/2 1/4 1/8 scene resoulution or so. Then would the aspect ratio be the same.
ok, i'll add something along those lines too...
Radiance
Thanks again.
I want also a light Picker ;)
Posted: Sun May 02, 2010 8:43 pm
by radiance
Radiance
Thanks again.
light picker ?
octane does'nt support lights, and never will.
it will be a material property... (eg emission)
Radiance
Posted: Mon May 03, 2010 4:22 am
by face
For the daylight-sundir-x/y/z.
Any 3D app has lights. I think it´s easy to use one of that light as sun. Or how should we enter the direction?
Posted: Mon May 03, 2010 7:57 am
by radiance
face wrote:For the daylight-sundir-x/y/z.
ahhh ok, for sundir it's true yeah, i will add a picker.
i thought you were talking about other lights.
Radiance
Posted: Mon May 03, 2010 11:54 am
by Amplitude
Hey Face, great work you did there with that exporter ! :)
but would it be possible to make it work for 6.5 also?
Posted: Mon May 03, 2010 12:24 pm
by face
Amplitude wrote:Hey Face, great work you did there with that exporter ! :)
Have you test it with 6.5?
I have used the 7.5 sdk´s, that works in this case up to SI2011.
I have´t install the 6.02 sdk yet, but i think, i can do it for the final...
6.5 was a web update, right?
Posted: Mon May 03, 2010 1:18 pm
by Amplitude
Yep I tested it and it doesn't load at all , but that was expected as .dll compiled for 7.5 and up aren't compatible with 6.x.
Yes I think 6.5 was a downloadable update.
Posted: Tue May 04, 2010 2:26 am
by nuverian
Thanks a ton for the plugin Face..And thanks radiance for helping this get better!
Thanks both in the end.
Posted: Fri May 07, 2010 9:39 pm
by face
I have finished the exporter for v2.2...
Posted: Sat May 08, 2010 10:54 pm
by face
Here a screen of the exporter with all options on...
The exporter is for the upcoming 2.2
All works fine, at least that, that i can test.
