Octane Solaris plug-in 2020.2.3.0 - 05-06-21[OBSOLETE]
Posted: Mon May 10, 2021 11:27 pm
Dear Octane community,
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for Solaris V2020.2.3 - for Houdini 18.5.532.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrate completely with Houdini 18.5 Solaris.
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launch it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
- Changes since 2020.2.1.2 - 04-08 Test-
-Known Issues-
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
- we are still experiencing issues with Octane nodes working correctly due to what appears to be issued with the version of USD that Houdini is built with.
Enterprise Subscription Downloads
2020.2.1.3 Houdini 18.5.532
OctaneX PR11 Houdini 18.5.532
Studio Subscription Downloads
Demo build Download
Happy GPU Rendering !!
Your team
OTOY
- Implemented Distant light and Point light
- Implemented Octane Daylights, Planetary and default Environment color in the render setting.
Now, the workflow requires Render Setting node as the BG is default to none(no Lights in the scene) - Support Refractions for USD Preview Material
- Fixed VDB Crash. Please apply Octane Volume medium if the VDB sequences does not load when scrubing the timeline.
- Other bug fixes
-Known Issues-
Demo build Download
Your team
OTOY
