connections lost on tool_composite after copy/paste
Forums: connections lost on tool_composite after copy/paste
Hydra Solaris
Postby WhyGee » Tue Jun 07, 2022 11:37 am
WhyGee Tue Jun 07, 2022 11:37 am
When I copy paste the nodes (see attached screencapture), the input connections to the tool_composite node get scrambled or disconnected.
I'm using OctaneSolarisEnterprise_2021.1.5.0_Houdini_19.0.622_Win64
(I'm using the legacy material / render workflow, haven't tested in Solaris)
Yaniv
WhyGee
Re: connections lost on tool_composite after copy/paste
Postby BK » Wed Jun 08, 2022 9:39 pm
BK Wed Jun 08, 2022 9:39 pm
WhyGee wrote:Hi,
Yaniv
Hi WhyGee,
Thank you so much for reporting this.
The issue is that the composite tool has dynamic pins and changing from default 4 to 2 has lost the connection.
Would you please keep the default pins to 4 and see if it works?
cheers
Kind Regards
bk3d
BK
Postby heimlich » Mon Aug 15, 2022 1:44 am
heimlich Mon Aug 15, 2022 1:44 am
keeping 4 pins wont work.. because the previous pins will be overwritten.. so if you put things in layer 1,2 you dont see them. I sent this issue to Juanjo today as well.
heimlich
Postby BK » Mon Aug 15, 2022 5:07 am
BK Mon Aug 15, 2022 5:07 am
heimlich wrote:keeping 4 pins wont work.. because the previous pins will be overwritten.. so if you put things in layer 1,2 you dont see them. I sent this issue to Juanjo today as well.
Thank you, heimlich! Just wanted to confirm if you are running the latest builds `Octane Solaris plugin 2021.1.5 - 08 08 22 [Test]` for H19.5.303.
We have set the default `Tool Composite` layer default to 4 but as you have said once we change the layer the node is created before updating the number of inputs, and the connections are lost. Copy/paste should work if we use the default 4 layers. Hope we could fix this in the later releases.
cheers
Kind Regards
bk3d
BK
Return to Hydra Solaris
Thu Apr 25, 2024 1:25 am [ UTC ]
