HELP! Duplicated frame problem
Forums: HELP! Duplicated frame problem
Discussion Forum for the Render Network
For support questions please visit help.otoy.com or contact [email protected]
Postby snahbah » Wed Feb 17, 2021 10:36 am
snahbah Wed Feb 17, 2021 10:36 am
I found a big problem – duplicated frames.
I have a project of over 1500 frame and had to go through every one to find the dupes, note them down and serenader them (sometimes twice)
Much like other people here - I was under a tight deadline, so I turned to RNDR. Ended up costing me more time and having to pull an all-nighter to fix.
Any ideas on how to fix this – OTOY support have been completely silent with my requests.
snahbah
Re: HELP! Duplicated frame problem
Postby bepeg4d » Thu Feb 18, 2021 7:49 am
bepeg4d Thu Feb 18, 2021 7:49 am
if you are using OctaneX to generate the .orbx file, please have a look at here:
viewtopic.php?f=139&t=76283&p=395753&hilit=rndr+command#p395753
ciao Beppe
Postby snahbah » Thu Feb 18, 2021 1:15 pm
snahbah Thu Feb 18, 2021 1:15 pm
Don't use the standalone - I'm using PR6 C4D to make the ORBX files.
Still having issues today.
snahbah
Postby snahbah » Thu Feb 18, 2021 5:15 pm
snahbah Thu Feb 18, 2021 5:15 pm
Apparently the 2020.2-R2 CUDA version works a treat and the problem is no longer there.
Sadly, I'm running news machines with Metal.
Any idea when the bug will be addressed?
snahbah
Postby bepeg4d » Fri Feb 19, 2021 8:35 am
bepeg4d Fri Feb 19, 2021 8:35 am
Ok, as suspected you are using OctaneX Metal.
We need to wait for PR8 for a fix.
Please follow my instructions on how to export the .orbx scene via C4D command-line, you don’t need to use Standalone:
Looking forward for your feedback,
ciao Beppe
Postby snahbah » Fri Feb 19, 2021 11:50 am
snahbah Fri Feb 19, 2021 11:50 am
Thanks. Tried the command line option. Can't get a save ORBX file from it. It runs and then no file.
It's also rather laborious if you imagine doing this multiple times over - every day.
EDIT: Spelling
snahbah
Postby bepeg4d » Sat Feb 20, 2021 8:05 am
bepeg4d Sat Feb 20, 2021 8:05 am
Ok, we figure out that the issue was that I forgot to say to press the space bar after dropping something in the terminal window.
Now also snahbah has tried this solution, and has worked perfectly, without issues:
Not only, exporting in this way is incredibly fast, compared with the normal export, the -nogui option is very useful in this case :D
Happy RNDR rendering,
ciao Beppe
Postby snahbah » Wed Mar 10, 2021 10:23 am
snahbah Wed Mar 10, 2021 10:23 am
Sorry, I could never get this to work. Not sure where you got that information.
I understand that this is a known issue and the team are working on it.
Any idea when it will function properly? I’m wasting money.
snahbah
Postby bepeg4d » Thu Mar 11, 2021 9:55 am
bepeg4d Thu Mar 11, 2021 9:55 am
yes confirmed, the issues is still not solved in PR8, but the command line method is working 100% also with PR8, please, give it another try.
ciao Beppe
Postby ultramajic.com » Tue Jun 01, 2021 2:23 am
ultramajic.com Tue Jun 01, 2021 2:23 am
this method is not always working for me... is there any update or a better explanation?
ultramajic.com
Next
Return to The Render Network
Users browsing this forum: No registered users and 17 guests
Thu Apr 25, 2024 6:25 am [ UTC ]
