OctaneRender 2020.2 LightWave Production build 2020.2.5.1
Forums: OctaneRender 2020.2 LightWave Production build 2020.2.5.1
Re: OctaneRender 2020.2 LightWave Production build 2020.2.5.0
Postby Lewis » Thu Sep 16, 2021 1:14 pm
Lewis Thu Sep 16, 2021 1:14 pm
Carlos3D wrote:R: Octane has always been like this in any version.
It shouldn't be an Octane issue but rather a LightWave limitation...
I believe!...
No, sorry Carlos, that is not what I'm describing there, people are probably missing key point here, INSTANCE polygons are used just for placing instances (imagine you have Polygons 2*5m with shorter edge and you use 100 of those to place car son the car park, you don't want those polygons (placeholder for car position and direction) to be visible eon render, you just want CARS that are instance don top of those. So CAR are ON in scene editor, but placeholder polys are OFF in scene editor.
Currently, in 2020.2.5.0 that is not possible/working while in all other previous versions it DOES work that way.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Lewis
Postby Mastoy » Thu Sep 16, 2021 1:41 pm
Mastoy Thu Sep 16, 2021 1:41 pm
Nope, I've been using this simple trick for a long time now (using deactivated "support" geometry for instances)
That's a problem if it's broken in this new version
Mastoy
Postby NemesisCGI » Thu Sep 16, 2021 11:14 pm
NemesisCGI Thu Sep 16, 2021 11:14 pm
Lewis is right, this use to work. Tested in Octane 2020.2.4.0.
Confirmed: If you hide the instancing object in this case a cube the instances still render in older versions.
Shaun.
Win 7 pro 64bit GTX780
NemesisCGI
Postby Carlos3D » Sat Sep 18, 2021 12:12 am
Carlos3D Sat Sep 18, 2021 12:12 am
I believe!...
R: Hmm now I realized
Sorry for my point of view
Tx Carlos
Carlos3D
Postby pixelsmack » Mon Sep 20, 2021 5:01 pm
pixelsmack Mon Sep 20, 2021 5:01 pm
Can you set polygon size to ZERO for that intancer placer? As a work around?
pixelsmack
Postby Lewis » Mon Sep 20, 2021 5:03 pm
Lewis Mon Sep 20, 2021 5:03 pm
pixelsmack wrote:Can you set polygon size to ZERO for that intancer placer? As a work around?
What if you use "polygons size" option :)?
P.S. I know some workarounds but regardless this have to be fixed.
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Postby promity » Fri Sep 24, 2021 4:22 am
promity Fri Sep 24, 2021 4:22 am
how about the beta version of octane 2021 for lightwave - does it exist at least for the "elite" who are allowed to beta test?
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Postby hdace » Mon Sep 27, 2021 10:58 am
hdace Mon Sep 27, 2021 10:58 am
Very much looking forward to the MacOS version.
Vote for Juanjo!
hdace
Postby promity » Fri Oct 01, 2021 4:39 am
promity Fri Oct 01, 2021 4:39 am
promity wrote:how about the beta version of octane 2021 for lightwave - does it exist at least for the "elite" who are allowed to beta test?
Strange - such a simple question, but still no answer. At the same time, beta versions have already been released for all other packages. Should we consider, in this case, the lack of information for 2021 for LW as a signal that the development for Lightwave will be discontinued?
Lightwave 3d
promity
Re: OctaneRender 2020.2 LightWave Production build 2020.2.5.1
Postby juanjgon » Tue Oct 05, 2021 8:29 am
juanjgon Tue Oct 05, 2021 8:29 am
I've updated this topic adding a new 2020.2.5.1 build including a fix for the bug in the instancing rendering introduced in the previous version and the macOS build.
juanjgon
PreviousNext
Return to Releases
Thu Mar 28, 2024 3:40 pm [ UTC ]
